Anyone running stickies?
Soooo.. I ordered a set of MTR Kevlars in the 40in flavor to replace my 40in Toyos. Mainly due to weight savings (30lbs) a tire, and because I wanted to try something new. Anywho, I think I accidentally ordered the sticky non DOT approved compound so if I end up receiving the stickies should I send them back? I love the idea of stickies but obviously I'll east them quickly. I do not DD the truck, I only drive it to and from trails, but sometimes many miles to and from trails, so keep em or re order in the dot approved version?
Thanks in advance for any opinions on the matter!
If you're going to drive on the streets to and from the trail, get the DOT ones.
How far away is your trailhead?
Where do you live (ambient temp of asphalt, and wet %)?
Yeah, you will eat stickies in a shorter period, but here in WA I run some 200 compound & they last quite awhile. (Prelude SH & old Camaro) - As in enough as my backup cars that it's economically viable since not my DD.
IIRC stickies are 80 compound where normal MTR's are 280, so while they are far softer, if you live in Canada & the trailhead is relatively close to the house, it might be a fun gamble to try a set.
I flat loved a set of bald Hoosiers from an old autocross car I had for a bit (on my E30M3), and the 200 compound RE-01's & a set of SO-4's are fun on a warm day, you just have to wait till they warm up for the flat spots from parking to go round (10mins/5miles).
Can you afford to try a set? Sticky tires are freaking awesome, worth trying once for sure.
I run Maxxis Trepidor compatision stickies. Also non dot approved. I run to and from trails at around 200Km.(one way)
They seem to be doing fine. Its not my daily driver and I always check tyre pressure. I have done around 10 000km now and they down 2mm.
The biggest problem for me is the tyre roll/flex. I run them at about 4 bar to get some road holding.
I live in Washington and most trail heads are within 2 hours of me, I maybe put 3500 miles on the truck a year max, all heading to trail heads. I got a smoking deal on these at 505 a tire which for a 40 is pretty nuts.
Bottom line is that you'll burn through the stickies faster than you will the DOT tires. However, with the low miles you're putting on the truck in a year, normal DOT tires would likely last you a decade and you'd be more worried about dry rot and carcass failure than you would about treadlife. So let's say the stickies last you have that time. If you got 5 years out of them you'd be satisfied is my guess. Yes? I don't think that 5 years is an unreasonable expectation for lifespan so I say go for it, they're on the way already anyway.
I like this reasoning! I will stick with them! Honestly I only keep tires for a year-2 years just because I always want to try something new as far as tread pattern! My whole reasoning for these is because, well, I'm "bored" of the Toyos.. If that's a thing? So if these stickies will last me almost10k I'd be absolutely ecstatic!
