Another Misdiagnosed Dead Engine After a Broken Timing Belt 2004 2UZ
Fzj80 1997
I just wanted to put out another heads up in not trusting your mechanic when they say you need a new motor after a broken timing belt.
I rolled the dice on an 04 that snapped a timing belt a few weeks ago and got a chance to throw in a new belt today. Scoped the cylinders before starting on the belt and no piston/valve contact seemed evident. She fired right up after I plugged in the cam sensor I initially forgot to plug in. Before that, the truck sounded like it didn’t have any compression while cranking for whatever reason which momentarily made my heart sink.
I talked to the mechanic that misdiagnosed the truck before I bought it and he said he performed a leak down test and it failed 5 out of 8 cylinders. Not sure if he actually did it, but the coils were all unplugged and the bolts were loose. Anyways, screw that guy because there’s totally some missing bolts and sorry to the guy that was mislead into selling me his truck. Hope this data point helps someone that runs into this issue in the future
Also, this truck had a timing belt and water pump service around 100k according to the sticker and was overdue by ~1,200 miles. The belt was a Continental and the pulleys seemed fine. Just go OE Mitsuboshi
Mine was was 230k miles "overdue" and changed it anyway caused I was bored.
I bought a 99 UZJ100 with 244,000
Miles on the ORIGINAL OEM timing belt
From original owner. On the phone he said the belt had been replaced, when we bought it for
4,400 $ and went thru the receipts no timing belt service ever! He had the serpentine belt replaced. The 2uz still ran good but I replaced the old cracked belt, aftermarket belts will not last that long!
I repaired 3 different motors with snapped belt (02’ 2UZ, tundra, 03’ 2UZ Seqoia and 5vz, 03 Tacoma) or shredded teeth and both 2uz motors were declared trashed by the “shop mechanic. The tundra owner cried when I fixed it and took her for a test drive, her friend , a Mercedes mechanic said I was ripping her off and she needed a new engine! Some people don’t know what the F#*c% they are talking about!
Sweet, one more for the books. I've yet to see a proven interference in a 4.7 2UZ-fe (98-05).
BTW: A leak down test, can not be done, with broken T-belt. We must have a T-belt on and timed properly, to do compression or leak down test.
So where does the conventional wisdom come from that snapping the timing belt damages the motor?
From Toyota, who obviously has considerable ability to influence popular thought. Why they said and didn't retract it is not clear. It is of course true for VVT engines which muddies the picture a bit.
To pile on: I seem to remember a timing belt thread on here that tried to determine if anyone had ever seen an OE timing belt snap on a 4.7...
i just helped a guy do a TB/WP on a LX with 330k on it. it was cracked but not broken. water pump had 167k in sharpie on it. luckly it was driven by a great grandpa
yes. i did at 203k towing with my tundra. i believe the tensioner failed, got a hard miss that got worse pulled over and tried to rev it at like 4k to see if it would clear up. broke the belt and cracked tie plastic timing cover. mobile mechanic did it in about 6 hrs and drove it home.
My belt was 200,000 over due and I did it first thing I got ownership, thank god it didn't snap during my test rides
Had an OE on my 05 4R in 2018, +-200k and about 13 years old... it was the first thing I had fixed on the truck, it didn't look bad at all. If OE snapped I'd wager something was spilled on it.
