Amby door latches....
Southern Ontario
I am having problems with the top (and bottom for that matter) latches. The spring doesnt seem to be pushing the top latch all the way up.... and the bottom is almost identical. A good bump and my rear doors can pop open.
I have popped off the door panel and tried to fiddle with it - but there doesnt seem to be a whole lot to adjust.
Is there a way to service (or even replace) the latches ?
Thanks...
you can always get different ones, what do the strickers look like. might be worn or even broken.
I am wondering what your tub looks like - more specifically your ceter channel out where it supports your quarters...
I think if it is rotten, there is enough flex from the weight of the hard top that deformation occurs - the actual clearances from top to bottom striker change...
Also, is your weatherstripping shot? I noticed a thicker weatherstrip seemed to keep my doors latched better.
What year Cruiser?
Good luck!
ive put washers under them to shim them up when they wear and it has worked for me good luck
I've got two washers under each side at the top. I had more with my previous doors.
My door panel is also currently off, and it looked to me like there were adjustments in the rods right near the handle, no?
What condition are your doors and hinges in? My old set of doors are 'twisted'. The top frame is not parallel with the bottom frame. That caused trouble.
On my current doors, the bottom hinges are 'pushed in'. The doors have been over-extended when opening, the hinges bent and so when the doors close they go further into the opening than they should be by about 4 or 5 mm.
Anyone have an extra bottom striker they want to sell? Mine works, but is cracked.
