Going on a year and a half now now and hasn’t skipped a beat.Haha thanks, I am in America. I am just looking for the other option where I can keep the fuse as well. Has the solution from O'Reilly's been reliable for you?
From the description not sure you are using the amp meter correctly.HKB MK3 Users: Could you check the MK3 fuse with a multimeter- while the fuse is plugged in and take a reading across the two poles onto of the fuse and let me know what you find. How many mA are you reading? If you pull the fuse and take an Ohm reading- what value to you read?
I was looking for a parasitic draw in my engine bay fuse box- testing each fuse for current draw. When I came to the MK3 ( which resides in the ALT-S fuse location) I found it was "live" drawing about 15 mA. It's not a lot of drain but that circuit should be off when the key is off. Inserting a 7.5A fuse in that spot- there is 0 mA draw. I reached out to HKB earlier in the week, haven't heard anything back yet.
Thanks
Not correct. Depending on the amp meter, say fuse has significantly lower resistance than meter, most all the current will flow through fuse and meter will only read the small amount going through it. Now if the meter resistance is way lower than the fuse it will read most of current but some will still go through fuse and not be measured.Im using a Multimeter in DC auto-mode so it reports whatever amount if current that's coming into it. Placing the test leads directly on top of the fuse to check for current flow. Checking Ohms just pulled the fuse and tested the two blades of the fuse on the bench. HKB read 4.5 Ohm's - standard fuse read 0.0.
Is that using it wrong?
You may also have current flow through the standard fuse, if the meter's resistance is high enough you would not see it.Huh - ok
Well thank you but are we splitting hairs? Obviously I’m getting current flow through the MK3 diode fuse when there should be none - it’s measurable on my multimeter-however it may not be reading the total amount of current throughput as you indicated.
Never the less- with standard fuse inserted there is no current flowing in key off state- and with the MK3 it’s allowing current flow which brings me back to the original ask in in my post- to know if others with the MK3 have the same readings.
thanks for this im going to do something similar in my 80I just installed a home made voltage booster as my system was generally about 13.4 - 14.2 running and my optima's were not lasting as long as they do in another Toy' with higher voltage. Optima (AGM battery) recommends 14.0-14.8 or so which lead me to want to try this and see if my battery's last longer. I think the optimas were not reaching full charge with just 14.2 max from the alternator.
I used a circuit tap that is designed to add a fused circuit from a fuse panel without bypassing the original circuit fuse. I just chopped the output pin down enough that I could make the assembly narrow enough for the battery fuse block on the LC and used a basic 6A rectifier diode and a couple of solder joints. Configured this way the rectifier is in series with the ALT-S fuse. Here it is done and in (5a fuse for bench test only):
I had considered a wiring modification due to the tight space but this worked great and can be returned to stock in 1 minute if needed. Now I seem to be running between about 14.0 and 14.8 depending on operating conditions. This should keep things brighter and pulling lower current, the radios seem very happy as well. Optimistic that I'll get longer battery life but time will tell on that. Not a bad mod for $10 and a few minutes cutting and soldering.
I installed a MK3 today and got the battery symbol on the dash. I'm totally lost. (running single AGM)Installed it. Started up and immediately got the battery symbol on the dash.
Any ideas?
Installed backwardsI installed a MK3 today and got the battery symbol on the dash. I'm totally lost. (running single AGM)
