Alcans Vs. SOA?
Western Slope, CO
I've been considering doing a SOA on my 74 which would be like 80% trail rig. Just wondering how 4" Alcans would compare flex-wise? Have heard good things about them. Also anyone know ballpark what you could expect to pay for a set?
I will never run alcrap springs, nor will any of my buddies.
will flatten, warrentied with now another flatten set. POS
depends. on $$$$ and what you want, what you do with it, and for what application.
They would be for a 74 FJ40. nothing too extreme, I only plan on running around a 33-35" tire. I just want something that will flex well for a SUA. That's the main reason I was leaning towards the Alcans. Of course it will see the occasional trip to Moab. Also what type of shocks would you want to set up with these?
I have Alcans on my 55 and love them, the ride nice, flex good and I have had no saggin in the 3 years they have been on there. It doesn't even lean. If you go with Alcan, make sure to make the shackle end of each spring 1" longer if you plan on going with a 4" lift to help with shackle angle. Be dead on in the weight you are going to carry, too much over stock and it will ride harsh until loaded.
It sits at the height you want (ie) 4" after it takes the extra weight you specify, unless stock weight springs. I'm clearing 35's on mine pretty easily right now with the 4" lift.
Just curious but with 80% trail time, 35" tires, why not SOA for sure, about 8 current threads on SOA and tons in search.
Then with the $195 a spring. Makes SOA a no brainer.
I would have to buy the axle housing(I have tools just don't trust my skills)cut and turned.450$ for Proffitts kit
Hy-steer 400-500$
New springs factory height(cause I have 2" lift springs now)$$??
I have a feeling it's gonna cost me more to do a SOA with the set-up I'm looking at.
Yes I've searched and read up on it. it just seems like things start to add up on a SOA conversion
And if I'm doing a SOA now then I should do a front disc conversion
I also plan on doing Saginaw PS, that has to be done anyway
I have a set of Alcans. I agree with the issue of being dead on the wieght you ask for. I went a couple pounds over...more like 200 pounds. I like them so far. I went this route because I could do it my self and I can put it back to original fairly easy if I had to. I ordered some ss brake hoses from man-a-who, shackles from liquid offroadand bilstiens shocks lockally. happy happy so far. My other opinion would be to go with a BDS suspension....I think it's the best bang for buck....cheaper and has one of the best warranties around.
When I did the SOA on my 40 I used stock rear FJ55 springs for the rear and stock front Fj40 springs for the front. I now have a longer wheelbase as a result. I aslo did a shackle reversal, custom bumper, shackle mount and installed custom beefy drive shafts. I also did a saginaw power steering at the same time. Where I did cheap out was with keeping a week tie rod that connects to a j**p pitman arm. I later had to replace the rod with a beefier one that I then had tubed and welded for extra strength. I should really go for a nice beefy high steer system but I just cant drop any more $$$ into the 40 right now. All in all its a nice sturdy, flexy suspension. I only run 35's but I like how it works. I definately get good articualtion and traction. All the various bits costs more than say a new set of lift Alcans would but in the end I am haapy with the results. I do have mixed feelings about the overall performance of the shackle reversal though.
Max
