This is a great idea. Knuckles and U Bolts
i just found out about these could be a good option but i think safety wire would be more secure.Not that I've ever seen, and I wonder why. On all essential aircraft fasteners it is pretty much mandatory, but not on automotive fasteners that would present a severe safety issue if they loosen. Wouldn't it make sense to lock wire them? Why wouldn't you?
forum.ih8mud.com
Yeah some wire and the tool is not too expensive plus you can go nuts with safety wire and do more!!!I'm in the process of getting all the parts together to do my front axle again, this time with new Longfields and brand new OEM spindles. I'm seriously thinking of lock wiring the steering arm nuts when it all goes back together. Running an 8' Fisher snowplow in the winter is putting some real strain on my front end components and I don't want anything coming loose.
Aviation safety wire, called lock-wire is a SS blend. It does not corrode.Yup, there's little jigs for drilling those offset holes for safety wire, I have some and they work for either bolt heads or nuts. And paint markers like on a few posts back work great for a visual indicator but the marks get removed by brush, sand, ice, mud, or rocks scraping over them, plus they don't provide any retention. Safety wire might get cut, rusted, or scraped off, but as long as it's still there it is keeping things in position.
And when it's broken or missing you know you need to 'check yer nuts.'
"Aviation safety wire, called lock-wire is a SS blend. It does not corrode."
Normally I'd agree with you, but the calcium chloride they are using with the road salt now here in Maine is extraordinarily corrosive. Ridiculously corrosive, in fact. Stainless just lasts a little longer, but even stainless boat parts will corrode here from being trailered around in the winter. I thought aircraft deicer was harsh but it ain't got nothin' on this crap...![]()
Whack the fluid film to that area after, or better yet, LPS HardCoatIt's terrible! I can't even get 3 years out of an exhaust tailpipe, after two winters you can crush the pipe in your hand due to the rust. Stuff should be illegal- how it's not banned as an environmental hazard I will never understand.
I wonder to what extent rust would affect the strength of the steering arm attachment lugs and nuts? It cannot be good for them at all. Would the cone washers make it worse or better? I didn't notice any pitting down inside the tapered areas when I had mine apart last time, but I'll be checking very closely this time.
They work great! One crucial thing is to keep the speed up when your drilling. The little drill bits snap easily and if you slow down before you just go fully through they snap.
yes thanks for the tip on the drill bits my hand cordless drill won't go fast enough I may have to invest in a drill press of some sort.They work great! One crucial thing is to keep the speed up when your drilling. The little drill bits snap easily and if you slow down before you just go fully through they snap.
My experience anyways
