after 315 the next step ..?
Panamá
Website
www.4x4panama.com
Hello all .. probably already know my Marilu ..
main.php
she's on 315 right now .. but those Toyos are start looking a bit smaller :hillbilly: so my next step should be a true 35" ( 315 = 34.6" ) I would like to keep in between 35" - 36" never more ( she's my DD ) with a good on road manners ..
It must be something like Toyo, BFG, GY MTR or somthing like .. which are my options .?
thanks !
David
I run Cooper STT in 37x12.5" on my DD.:hillbilly:
I think my wife will catch the size diference .. and the idea it's shy didn't .. ! actually which it the real size of your tires ?
VERY nice looking rig!
Well that answers my question about putting 12.5" wide tires on a 7.5" wide wheel!
Do you need to run any wheel spacers Kevin or do the wider tires make up enough
width to fill the wheel well?
My old style MTR's are perfect. Not too loud, seem to be wearing well and should perform really well off the pavement.
The 37's do a good job of filling the wheel wells. For me the fitting is all about getting the most travel/flex, using all of the available wheel well space, don't really care about "looks". If anything would prefer a slightly narrower tire.
With this combo I have to run spacers. IIRC with the Tundra rim width/backspace, the tire is moved in ~5/8" and I run 1.25" spacers, so the tire center line is ~5/8" outboard compared to stock.
It's very tight, for sure not running chains, doesn't take much mud to make them rub. When fully flexed, there is maybe 1/4" between the sidewall and frame/wheel well. When compressed straight up, the tire just touches the outer fender edge, both in the rear. A slightly narrower tire would be easier to fit, but these were the narrowest I could find.
Tapage,
Go for the KM2 in a 345/75/16. Check it out on the BFG site, 36. somthing/ 13.50 or so. Sounds like a great option.
bit bigger than I'm planning but yes are great option .. where do you found 'em .. coz In the Tire Rack I couldn't find 'em ..
There is any BFG KM2 in 325/75R16 . ? ( or any other brand ) 35.20" seems to be a good number ..
