ADVICE NEEDED: BOG/DOGGING WHEN ACCELERATING
Appleton, Wisconsin
hello friends,
firstly I want to apologize! I always feel a little hesitant that I will get the 'wraith of mud' when I post up a new thread asking for help. "YOU DID NOT USE THE SEARCH BAR!!!!"
Any whoodle doodle. Of late, I have been having a weird issue with my 96 lx450. After a certain point (unknown the cause), when I am accelerating, the engine will struggle to increase speed. It makes all the noise and it sounds fine, no misfire or anything, but I cannot gain speed. It feels like some has a big rubber band on the back, just waiting to snap back. Sometimes it will not rev more than 2k rpm and others it will, but the problem will remain. Either way, when you remove overdrive or engage PWR button, the behavior does not change.
Where it gets confusing is when, you put it in neutral, the engine revs fine and is really happy.
Could this be because of the 35s and stock gearing? Or something else?
anything would be greatly appreciated
Thanks
Jack
Do a SEARCH DAMMIT!
No, thanks for saying that.
I cannot help much, but the fact that it has times when it limits to about 2000 RPM, is an indicator of something specific. Some other will chime in. I want to say it's the EGR or IAC valve.
Check your codes if there are any codes thrown. Then advise. That MAY pinpoint the issue.
Good Luck!
Any history on the cats or the transmission?
Wiring harnesses shorting out on egr pipe.
Sounds like fuel starvation. Have you changed the fuel filter and in tank sock/strainer? If not, I would do so and bet on the strainer being sucked in and restricting flow.
had the same thing on a '94 stuffed the NSS with dielectric grease, problem solved.
No transmission problems, other than a very slow leak somewhere, TCase most likely. I am only running one cat with one o2 sensor. It's been working fine up until late. Could that finally be coming around to bite me in the butt? Also I have a PO125 and PO135 code, both O2 related, correct? My brother and I are torn between fuel and electrical. I have not touched anything related to fuel of late, but I have wired in a Cb radio. Maybe that's the problem solver?
First off check for exhaust leaks because leaks will screw up the 02 sensors.
Next I would pull the MAF and clean it with a sensor safe cleaner or brake cleaner.
If this doesn't help test the ECT probe in the block... carefully.
You can test the TPS, should run between 11 percent at idle to near 80% at WOT, but more than likely the TPS is OK.
Had this issue a year ago and noticed she was a dog till ECT hit at least 180 degrees.
Used data from my BlueDriver OBII sensor to narrow down the issue to ECT by downloading real time conditions once I finally figured out what the heck I was doing and what the data offered.
On my 94' I had a lot of hesitation and after trying a ton of things it ended up being a short on the wiring harness by the EGR pipe. It results in intermittent and hard to detect shorts that cause misfires. I searched "hesitation" over and over when I should have been searching misfire.
See if it runs fine in reverse.
I have had a similar issue. Was throwing the P0125 code. The bogging seemed to only happen after I reset the check engine light and it (the bogging down) would be momentary. I put a new O2 sensor in it yesterday and have not thrown the P0125 code sense (would throw it frequently) and no bogging down yet. Next item to replace for me is the fuel filter if the problem comes back.
Side note is I have an Ultragauge and could watch the 02 sensor failing and then throw the code. Getting much different readings with the new O2 sensor in.
I'll check to see if it runs fine in reverse. Also, it only has one o2 sensor and no cats. I removed the cats when I we had to make a downtube/ y-pipe. What/where is the NSS?
We've cleaned the MAF, the TPS, but have not made it to checking the fuel system or the o2 sensors. Probably going to be next
Basic engine principals...you need air, fuel and spark. Well since the engine runs, you have all three, but when you have a lack of power, I think it does not have enough of one or more of these. First thing I would look for since it is easy, is to check the fuel pressure, check at idle and then also while reving it, if you get a significant drop when reving then look at changing the filter or pump.
After that, I would look for an air restriction. I doubt you have a MAF problem, because if that was the case, then you would have real bad performance almost at all RPM ranges and when you step on the gas from idle, you would notice a hesitation. If it runs fine at low RPM and when not under load, it very well could be a collapsed cat. Now if I recall correctly, the cat is welded on the downpipe, so there is no way to disconnect it and drive it without a cat/muffler real quick to test that. The solution here is to drill a small hole in the exhaust in between the cat and the header, weld a little hose bib on there and put a pressure gauge on that. At idle, you should see about 1-2 PSI, rev up to 2000 RPM and you should see it go up a couple PSI from what your idle was. If you are seeing high jumps or if you see it gradually increasing while reved at a constant rpm, then you have a blockage. If you ever see anything over 10 PSI, you have a blockage and it needs to be replaced.
Next is spark. You know you have spark, but what about correct timing. Use a timing gun and check the timing at idle, jump the e1 and te1 pins first to put it in service mode first so you can get the flat timing. Stock is right about 3*, but many owners (at least in the US) have advanced that since the quality of gas here much better than many other parts of the world. If yours is a few degrees higher than 3, dont worry about it too much, it just means that a PO advanced it. The number that it should be varies on what octane you plan on running and also what elevation you will primarily be at. If it is too advanced though you will get pinging, the knock sensor will detect it and retard the timing significantly, resulting in poor performance. Now, after you confirmed you have 3* or so of timing when in service mode, take it out of service mode and check timing, it should have come up to about 10* or so at idle (add the difference if not at 3* in service mode), when reved, you will see it advance more to the point where the timing mark may jump outside the marking bracket. If you dont see any of this happen then you have a problem with the timing advance system.
Maybe to help more let me ask this...do you have a check engine light? Do you have an OBD scanner? Post any codes if you can get them.
I suggest you take care of the engine codes and see if the problem persist.
So much of the above advice is going to send you on a witch hunt and you will dump money on parts. Use your OBD 2 codes, it's called 'On Board Diagnostic' for a reason, and its OBD 2 which is usually pretty decent at directing your attention to the areas causing problems quickly.
Fix whats causing the code FIRST, once you've cleared the code then you can start jumping to conclusions. an O2 sensor can put your rig into limp mode (lowers the rev limiter). Seeing a code but not using it to help fix a problem is like not listening to a doctor when they say you have strep.
Not trying to be a prick, just want you to learn how to do diagnostic work the right way. Once you address and clear the P0125 and P0135 the problem may be fixed, if not it may kick another code at you. If that doesn't happen then we can start down the old school road of deep diagnostics. Until then you are literally just shooting blind, which sometimes works but is often very expensive and frustrating.
The problem could be any of the following:
  • O2 sensor (Codes present, highly likely)
  • loss of fuel flow
    • Worn / exposed and corroded wires on the fuel pump
    • clogged filter
    • injectors clogged / not pulsing correctly
    • clogged fuel sock
    • bad pump
    • bad FPR (common cause)
  • loss of spark
    • dizzy
    • rotor
    • wires
    • plugs
    • myriad of electrical connections / relays
    • igniter
    • coil
  • Other electrical
    • ecu
    • relays
    • electrical harness damage (egr burn through is common)
So you can see that list covers most of the systems in your rig. Lets get the low hanging fruit out of the way first then we can navigate through the rest.
I'm having this same exact problem. Usually first thing in the morning in get out on the road and it looses power while accelerating. Yesterday it bogged down on my and died twice at stop lights. I had to keep the throttle up to keep it from dying. I don't even know where to begin. I have no codes associate with it which leads me to believe it's probably not a sensor. I was thinking a fuel line problem.
If there are no codes I would first replace the Fuel Pump Relay. The contacts get corroded and cause issues but no codes.
Throw the old FPR in the spares bin. If that doesn't fix it then check the harness at the EGR for burns. If no burns are present then I would hook a volt meter up to the fuel pump power supply and monitor it while trying to duplicte the situation.
If you see loss of voltage you then its almost always the FPR.
See this is why ih8mud is the best forum out there! Thank you everyone for your advice! I'll be getting to fixing the codes and go from there! If anything, they'll finally be gone and I won't have to look at them anymore!
