ADVICE NEEDED: BOG/DOGGING WHEN ACCELERATING
Sorry, I missed where you posted your codes...I am a little confused...do you have cats or not? One post says it has a cat and the other says it doesnt. In any case, P0125 is a temperature code, basically the engine is not getting up to temp in time. This could be the result of a stuck open thermostat. The P0135 is stating that an o2 sensor is not heating up. Your vehicle should have two o2 sensors, a downstream and and upstream. The P0135 error indicates that it is the one upstream (before the cat(s)). If you only have one cat...which o2 do you have? Is yours before or after the cat? You will need two to keep that ECU happy.
On the OBD2 rig I believe the down stream O2 sensor is there to check the efficiency of the cats ONLY (OBD2 gurus correct me if I am wrong). I don't believe it has any other control over the engine. The upstream O2 sensor is used to set a base line for the ecu to compare with the down stream one AS WELL AS providing the ecu with information on the air fuel ratio so that it can adjust the injectors pulse and timing advance.
I'm not the most knowledgeable on the OBD2 system, consult your FSM it will tell you exactly what information each sensor is sending to the ecu and how the ecu uses that info.
Because you have both codes for both o2 sensors I suspect your sensor is bad. If that is the case your engine will likely run in limp mode because it has no idea whats going on in the combustion chamber. This usually triggers limp mode where it dumps a ton of fuel into the cylinders, retards timing and sometimes limits revs. All of those things are designed to protect the engine and will reduce power.
Final answer:
I do not have any cats! I have one o2 sensor in the system, and it is the down stream one. Where it gets funky is because I have been running it like this for 20k miles. I have been meaning to add cats but i just haven't gotten around to it.
just because it was running fine doesn't mean that running only your downstream o2 isn't the problem. Consult the FSM again, it will tell you exactly what each sensor is providing to the ecu and what the ecu is doing with those signals.
