How long is your MC? I am looking to add a booster and Racer65 sent me to this thread. I have the JT adapter to an older Toyota MC now because it has front discs. Also what are the dimensions on that booster? Id like to compare.
Thanks! That is exactly what I needed to see
What sort of adapter?Same combo I'm running. Only difference is I used an adapter at the firewall. It's stops better than my 80.
I have the JT spacer now running my master for the disc brake conversion, but no booster. The studs on the booster wont work with the spacer which is designed for the through holes of the MC. Is there some other spacer I have not seen yet?JT Outfitters makes a spacer
Thanks for the write up and pictures @wngrog! Awnsered all of my questions regarding this upgrade.![]()
looking at this conversion for my V (LV). It looks like the city racer booster suits the small hole on the firewall, unlike the larger hole on later models. do you know if there is a toyota equivalent booster that may also fit the small hole. If you didnt have the carby clearance issues is there another way you might have gone, that could work better. Mine is RHD and wont have carby clearance issues. Thanks for the write uphoping to avoid installing a later pedal box and any unnecessary mods. thanks
