Hi all,
Jumped in my '97 LX450 couple of days ago, started and immediately put it in reverse. No brake pressure and no brake braking... Shifted to N, paused a moment, then had pressure and acted normally. ABS light on in dash for months, but no indication of an issue until now. Later in the day I drove it to dealer for inspection. Dealer is closest mechanic so didn't want to risk driving into Charlotte and having a brake fail.
Dealer says code 51 (stored pump motor locked) and must replace ABS actuator ($1500+ for part) and master cylinder ($700+ for part) plus labor and all the other charges they add on. Says part will come from Lexus dealer and that the part is Lexus only. When I questioned, "really? standard Toyota LC from same year won't work?" he replied, "look I'm not a parts guy. book says Lexus only". He never mentioned module...
My questions -
Thanks
My questions -
- Is the ABS actuator really a different part for the two badges?? I'm guessing no but don't know everything
- Could an ABS actuator impact the brake function in this way?
- Why would i have no brake pressure at startup and then feel and work normally after short idle?
Thanks
Incidentally, my ABS light was one for 12 years before the bulb burned out. I am part time rear wd so the front sensors weren't picking up the ABS signal!
He has 285s and never been able to lock up and activate ABS on dry pavement, and here I am just about locked up all four tires and squealed the tires a little.
