? About ARB front bumper?
Lexington, KY
Finally found a a good used one for a good price. Can I buy just a turn signal lens cover to replace the broken one from ARB? And is there a way to attach my African front license plate?
The one I want to buy
My license plate
Not sure about the broken lens. But this is how I mounted 2 license plates to my ARB front bumper. Front state license which is required by California and then one for fun. Drill 2 holes each license, then nut/bolt them up.
You might need to tilt the 2nd picture to get the best view.😊🙉😊
Tim,
The last time I had an ARB I needed to replace the light covers and they didn't show a kit on the site but when I called customer service they gave me a part number and transferred me to a local dealer. I am lucky as there was a warehouse a couple towns over and I could actually just pick up from them (this was years ago). It wasn't crazy expensive but I couldn't buy just one lens, it was both sides and IIRC it came with a couple other perishable/expendable parts.
As for the license plate, back in the day you could get a bracket that clipped over your fairlead roller to display your plate but if you are hip and happening with new technology and run synthetic you won't have that option. You may be able to get some bar clamps to mount to the lower crossbar just above your winch.
Also, the green looks really good on the truck. :)
Thanks. I keep reminding people that I’m not as crazy as I look.🙈
Tim,
Thanks. They offer the two light kit for $50.
They said no lens cover when I called arb. I may be able to use a flip up plate bracket, not sure if they will fit. Why does synthetic stop the bracket use? I think this winch does have synthetic rope.
They show up on ebay every once in a while. I had to replace one of mine when it split in half. I may have the other one in my parts bin.
I keep those light holes open on the ARBs that I have because it's a convenient spot if you need to use a Hi-lift jack on the bumper for lifting.
Good point. If you’re careful you can also use metal shackles also. Probably also soft shackles but I’ve for sure used the metal ones.
Thx ! I saw these and regular orange lens covers on eBay as well. I am gonna go see about the bumper Monday and then order one of these options I guess.
If you do I would be super happy to buy it.
I will check. My parts bin is up high in my garage and super heavy.
UDPATE: found them. Sent you a message @Tim Herald
BTW, change those old halogen bulbs to LEDs.
Waterproof, bright, and only about $17 a pair. They needed minor modification to fit.
