1988 LC FJ62 - first time poster w/ trans issue
describing problem with example.
Drove it 25 miles one day - no issue. Drove it 15 miles the next day to a Dr appt - no issue. 30 minutes later, it would shift from 2nd into neutral. Tried 3rd gear on the shifter as well, no luck. Reverse wasn’t working either. Essentially gets right around shifting at proper RPM in 2nd and kicks it to neutral.
Problem is intermittent, not there all the time - seems to appears when warm.
Drained ATF, replaced both fluid and filter. Nothing obscure in the pan.
just looking for any pragmatic next steps before a full trans rebuilt or if anyone experienced something similar.
Thank you again.
Thank you again.
