but that almost always is accompanied by bitching and moaning as well.I had a loud whining noise too, then I got a divorce and it went away.
My tire does not rub on any of the body - it just fits more snug against the tube framework of the tire carrier. Do you have the early tire carrier?@TEakins I think I know exactly why that wider tire fixed your rattle. If I didn't mount that 2" spacer behind my 10.5" tire it would press against the body, causing pressure which would not allow it to rattle. I didn't like that idea because I was worried it would rub my paint.....but it could be a solution if it bothers me that much. Thanks for the info.
Yeah mine is the early version....the square style that is on the right hand side.My tire does not rub on any of the body - it just fits more snug against the tube framework of the tire carrier. Do you have the early tire carrier?
Is your rig carb’d? They can make a “whining“ noise from the increased air flow into the venture at high rates. Just a thought.…it comes and goes in relation to the gas pedal being pushed to maintain speed.
