A 200 is meant to have 37’s
Roger that. I’ll get to writing something up. Maybe I’ll make time tomorrow evening.
Mostly in Spring and downtown.
Preciate the welcome man. I’d be happy to get some Houston guys together to talk about some ideas. Maybe a Sam Houston trip to the woods.
Nothing but respect and gratitude for you man. I’m actually collecting parts to do the crawl retrofit you put together. On the original note, the suspension is nearly stock, the only thing I changed was the rear lower links for compression fitment front to rear, tires still BARELY fit. No spacers, no lift pucks, just leveled the front and rear with the sensors and left everything else OEM to get a OEM+ baseline. I kept both sway bars and took a trip to Arkansas to see what I could identify as a shortcoming in “N” height and made 99% of my trip without having to use the “H” AHC setting. I’ll do a proper detailed write up and we can further discuss if you’d like to give me some input. Most issues were in the rear, front was flawless after very slight bumper trimming (in my relevancy). View attachment 3366546
Thank you all that have contributed to ih8mud. I hope to pass it along and get a few more safely modified vehicles out and about. It really is easier than anyone makes it look.
Houston guy here in the woodlands...Totally down for a Town 200s meet up. Also need to see this beast on 37s in person,,,
Any updates on a commercially available body lift kit?
Im a bit jealous of you LX guys. I so want to go 37s. I’d even spend time trying to find a solution for the LC KDSS. It’s the fender trimming that I can’t bring myself to consider yet.
Not gonna happen unless KDSS gets removed - or you run a 0 offset wheel with tundra front end to clear the 37s from the KDSS arm on the driver side. Then your scrub radius will go extremely positive with other clearance issues
I've been contemplating removing KDSS, running a front Tundra sway with links (since im running tundra front end), and no sway bar in the rear with a longer shock & spring combo.
But dang, I really do like the way my land cruiser drives on the road with kdss.
I do have a slight rub on the front sway bar at full lock sometimes. Bothers me 0%. Bottom pic is in high mode.View attachment 3320839
Sorry if you have listed it elsewhere but what exactly have you done to fit these? And the wheels used to get here would be helpful as well. I want to do a carbon copy of this. Thank you for showing it can be done!
Any updates or details on the body lift?
I put together a parts list for the body lift that I installed which I think is in the posts in this thread, the last missing piece was some small drop brackets for the radiator. I have the parts to make them, but have been totally swamped, and then forgot because I suck.
I think I could make them fit around the sway bar and KDSS if I could find a 37 which wasn’t 12.5” wide and if I was willing to body lift or cut the fender. My 35s don’t rub at all on +35 offset and there is still space before they would contact the arm or sway bar. If I made my own KDSS relo brackets I could push the bar another 1/2” forward, maybe a bit more. It would be close
I'll preface by saying mine is specifically for 37x12.50r17 BFG ko2s. They book at 36.5" but on the truck measure 35.5" so essentially a slightly worn 36" tire. I'd imagine comparing to a 37" Toyo MT or GY MTR they would be larger and more complicated to fit with more aggressive sidewall lugs height/width. The KO2s are 15/32" tread depth new and most others of that size are 21/32" which accounts for ~.2" shorter than some 36" tires. I think I could fit a true 37 with some adjustments but who knows.
My recipe is:
Sensor lift front and rear
Method 314 17x7.5" +25
Timbren AOR in rear position for front control arms and custom chopped down cheap poly bumps for front of front control arms.
Timbren AOR in rear frame position of rear axle
1&1/2 hockey pucks bolted to bottom inside of coil perch on rear axle. (assists Timbrens on big whoops and hard bottom outs-does not limit compression travel off road when articulating one side at a time)
Remove front mudflaps
Remove screws securing front inner plastic wheel well liner, push forward and re-secure in existing holes, cut some plastic parts here & there. (there is a writeup on here for this in the "fitting full fat 35s" thread- I think)
Healthy chop of the front body mount
Cut plastic over pinch weld and cut/grind pinch weld and other metal below
Alignment specs:
Camber on the low side between +.5* to 0.0* preferable closer to 0.0
My caster is 2.5-2.6* I'd like it to be 3.5-3.7* but not sure how much further forward that would push the wheel and maybe create new contact.
I like many others kept seeing 37’s on lx’s and couldn’t resist. Actually had them on since beginning of June. 37x12.5r18 falken wildpeak r/t’s, wheels are +25 offset. I’ve been messing with spacers to see what it would be like with a 0 offset. May swap wheels in future.
Cut 2” off the front fenders, hammered the pinch weld as best I could. Cut the forward most part of the body mount and welded a cap back on. Then cut about an inch off the front of my sliders and welded a cap back on. Also cut the front bumper wings back to match the fender. Lastly to gain some caster I installed some ome uca’s
The rear was a little more involved as I hadn’t seen anyone cutting into their aftermarket bumpers. Seems like most build something to match after cutting the front of the rear bumper plastic and cutting/hammering the pinch weld back. So I cut the bumper plastic back, as well as cut the front of my dissent bumper back about 1.25”. Then cut and hammered back the pinch weld.
Some things I still plan to do aside from fixing anything that still may make contact. Fab some sort of thin aluminum cover for the ahc pump/reservoir area. Bought some bump stops from perry parts but I’ve been talking with Patrick about him making me some longer ones possibly in the future.
Maybe this will help convince others to cut up their bumpers!
Cut 2” off the front fenders, hammered the pinch weld as best I could. Cut the forward most part of the body mount and welded a cap back on. Then cut about an inch off the front of my sliders and welded a cap back on. Also cut the front bumper wings back to match the fender. Lastly to gain some caster I installed some ome uca’sView attachment 3429882
Awesome work.
Are you looking to fit a body lift at all especially if you're looking to go more aggressive offsets?
For my rear bumper I bought some inexpensive rally flaps from Amazon and cut them to fit the bumper snap and then used the factory mud flap screws to mount them in the wheel well.
Rally Armor MF12-BAS-BLK Basic... Amazon product ASIN B00C3AIOTY
The perry bumpstops will work perfect if you also get the long-travel rear bumpstops. They still tuck real nice under compression. I had to roll the rear fenders with 0 offset. I spoke to Patrick and that was what he recommended for 37s for me. I’ve used them off road for about 4 months now and no issues.
Awesome work.
I thought about it, for some reason I’d rather just cut stuff.
I’ve been trying to decide what to use as a liner. May give those a try.
I also “rolled” my rear fenders, with a big hammer! I know when I asked him about different length bumps he wanted me to send some pictures, haven’t had a chance.
Is everyone running 37s with stock gears????
I’ve got 4.88’s.
I’ve got 4.88’s.
I know offset will impact this, but one reason I went with a body lift was to avoid dropping the rear bump stops when fully articulating the rear. Without a body lift my tire was hitting the inner wheel well with about an inch of travel left. Didn't want to mess with opening up the wheel well and all the interior plastic getting moved around.
