- Thread starter
- #21
All good questions and I definitely thought about the pros and cons of doing a new ARB with compressor or Harrop locker vs. the Toyota locked axle.Bama-
What was the preference for swapping into a used factory locked axle vs installing a Harrop E-locker or ARB into your existing axle? Cost savings or the challenge or something else?
I am enjoying watching you pull your truck apart, commend your wrench skills especially tackling this challenge, but it seems like a lot of added hours, effort, $$ & reliability risk retrofitting your truck with different electrics( ecu swap, different wiring harnesses), new brake lines, 18yr old actuator, and the time of physically swapping the axles; simply to get a locked axle.
Harrop E Locker + set up + install costs around $1700-$1900 otd; ($900ish for the locker if you DIY set up and install)
One thing I forgot to mention is the LX is actually my wife's vehicle that she daily drives. She is pretty against me adding bumpers to it bc she thinks it looks "dikey" lol. So I figured putting lockers in it is something that wouldn't change the appearance (obviously), but would really enhance offroad performance. We usually take her car to do long travel camping trips instead of my 60. Our plan is to keep her LX long term and let our kids drive it one day.
The reason I chose to go with the Toyota locked axle is strictly because of price. A local TN Mud club member posted up that there was a wrecked '99 Land Cruiser in a local Pull-A-Part with the rear elocker. I went to go scout it out and it was clean and looked good to go. It took us about 2 hours to pull it and then I hauled it home. It's sat in my shed since last December. Here's the kicker, I paid $108 for the whole shebang. That's a freakin steal in my book and I would have been crazy not to pull it.
So as far as time to do this swap, it really is a simple swap. Everything is a direct drop in, no cutting or anything required. All in, it has probably taken me 6-7 hours to swap axles and put in the AHC shock spacers and 80 springs.
Like you mentioned, what's the point in swapping in an old 18 year old axle that probably has been sitting for a while? I took off the old rotors, calipers and pads on the '99 locked axle and threw them away and swapped all of the good new parts from the LX over. Bleed the brakes and she's good to go.
Once I get the Slee CPU in on Tuesday, I will update the thread on how I wore everything. I did get the factory locker switch out of the '99 LC, so it will look factory. I'm planning on building my own harness from switch to Slee CPU, to locker actuator.
I just finished up the swap this morning and took it around the block and I think it rides smoother than before with the new 80 springs. I have a sensor lift, so I think it definitely helped lower the AHC pressures.
Next plan is to drain the old gear oil and refill with new. We have an overland trip to the Ozarks next weekend, so I'll get to test out the locker and will report back.
