- Joined
- Jan 6, 2012
- Threads
- 341
- Messages
- 10,935
What emissions requirements need to be met? What are the standards in your State? Is it just a sniffer test or do all the ecm factory monitors need to pass?
Remember when I first started the Rear Turbo Thread, I definitely got some discouraging remarks, LOL. But I have grown to love the IH8MUD community, and you too Ryan.I don’t want to discourage anyone from stepping outside of the box of ih8mud. We often wear blinders here.
Remember when I first started the Rear Turbo Thread, I definitely got some discouraging remarks, LOL. But I have grown to love the IH8MUD community, and you too Ryan.![]()
You got room for twins by just removing the spare, just sayingWell the turbo has been done, the standalone has been done, they just haven't been done together to meet OBDII emissions.
I dont see why it would be any different with emissions. If stand alone has been done, adding a snail to the mix really doesnt change much, just all in the tune. It might even run cleaner if done right.Well the turbo has been done, the standalone has been done, they just haven't been done together to meet OBDII emissions.
Don’t some of the aftermarket ecu’s have an obd port?
So sounds like all you have is the sniffer test either as you drive by it on the road or get the sniffer at the station. If that's the case then a stand alone should be fine. If u need obd2 functions to work because they do more than a sniffer then perhaps give Unichip a call and see if they can build you a ecm to work with your setup. You could also register it in a different County or state.
The 2uz TRD supercharger crowd if I recall has good reviews of Unichip.Nope Virginia has an OBDII test. Unichip had a chip for the 80 and it was worse than running without it.
http://www.deq.virginia.gov/Program...leOwners/OnBoardDiagnosticSystemFAQ.aspx#o2ei
True, but they may be able to build him a piggyback with all of those functions. Not saying I know for sure, but he could inquire. Current piggybacks may work too. I had success with split second on mild boost applications although it's pretty basic it worked. Map3 may also be a route worth looking into.10-15 years of ECU technology difference separate the 2. People use them on modern cars as well. The ECU in an 80 is not the same. There are no wideband O2's, no MAP sensors, etc. It is technology from 25 years ago.
I agree technology has come a long way. Not sure why a piggyback won't work on a 1fz, my 4runner has the same Era fuel injection and it worked fine piggybacked on 12 lbs of boost until the map sensor locked up. It just forced the ECU into open loop at a commanded boost and then took over. I had to call the company to figure out how to engage the right settings. Otherwise it would try to make changes in closed loop which didn't work for obvious reasons. I forgot he changed displacement of the motor, so that throws another wrench into the loop. I'm just trying to give the guy a couple directions to look into. I personally have no desire to own another 1fz and never got far enough with my last one to go forced induction.I wouldn't waste my time or money on a piggyback. again. It has never been used successfully on a USDM 1FZFE turbo. Lilevo, who owns a 150mph 1/4 mile evo couldn't get it to work. I tried two different tuners they couldn't get it to work. EMS couldn't get it to work. There is a guy here on mud in NC that has had 2 shops try for 6+ months they couldn't get it to work. Again you are trying to piggyback an ECU that was probably engineered back in the early 1990's almost 30 years ago. Technology has come a long way since then. You'll want a wideband, you'll want a MAP sensor, you'll want more defined control over the injector pulse width, you'll have to have hot and cold start tables, you'll want knock protection and maybe even map switching for different fuels, etc. You only get that with a standalone.
