VC-120 should be fine, not sure what else to try, it is puzzling for sure.
Have you found a cause of your problem or taken it to a dealership? I'm having the same code 25 problem and I've been working on it for a long time. Any information will be appreciated.I did the helicoil and it worked great and held strong so the manifold is now sealed but I’m STILL getting a lean code so I switched the oxygen sensors between the PAIR valve manifold ports 1 & 2 (again, these are new sensors BTW) because I read in another thread that the 93/94 NTK o2 (24080 and 24044) sensors were specific for the 3 cylinders. After switching the sensors, the idle was spot on. I went for a drive and it seemed a tad sluggish before 2000 rpm’s then it suddenly began to stumble at idle and almost stalled at the light and then started being really sluggish and then the CEL lit up with a code 26 so now it is running rich. I used a stethoscope to listen to whether all injectors were firing and all 6 were ticking. I’m getting a vacuum tester/gauge because the smoke test checked out fine and I will test the VAF again, but I’m at a loss and may have to take it to the dealership depending on what I find.
Seeing as the 93 and 94 trucks are both OBD1 they can use the same ECM/engine computer ( 95 to 97 are OBD2 and their ECM won't work). Problem is, the 93 trucks had a problem with their ECM, so Toyota issued a SB to replace the older 93 ECM's with an updated part number used on the 94 trucks. With such a limited supply of these "one year only" ECM's being available* this is all the more reason why it's a good idea to buy an extra ECM from a 94 that's being parted out so you have a spare. *I just checked on line stock with Napa, Auto Zone, O'Reilly, and Pep Boys, NO ONE is showing any stock on the 93/94 ECM'.I found a problem that may have been throwing the error code 25. It was the O2 sensor heater voltage (HT2) that was not generated in the ECM. The HT2 voltage is around 14.2 V while engine is running and it's 12V with just the ignition ON. I was getting 12V with ignition ON and only 5V with the engine running. I was able to find this because the bank 1 (HT1) was working properly. After fixing the ECM (a bad soldering on the 5W resistor) I began to see the multimeter needle flipping and I stopped seeing the CEL comes on while driving.
Very easy emissions testing in NM but at this point
I agree w/ @Dave 2000 .Solved: The EBay/Amazon VAF eliminated the CEL and the lean condition however it still had a significant intermittent miss that would periodically pop up at a red light or randomly when idling otherwise it ran fine especially when the RPM’s were up past idling… So I checked the compression and started to get vastly varying readings on my #5 cylinder -all other cylinders were reading 190PSI consistently but #5 was as high as 180 but as low as 40PSI when tested randomly over about a month’s period of time. I had done a compression check multiple times before and never got below 189 on any cylinder so I was thinking it was the autozone tester, so I borrowed another and the same thing happened. I finally bit the bullet and took it to a shop and told them about the whole intermittent code 25 and paid for a diagnostic. They also pinpointed the miss to cylinder 5 and said they got 60PSI and refused to work on it because they said it would be in the shop too long with the current machine shop turnaround time being at around a month, according to the owner of the shop. They also couldn’t reproduce the conditions for the CEL so I’m hoping that’s in the past for good. I am going to do a leak down test but the previous test was fine, but I was told by the shop that it wasn’t the head gasket because air definitely wasn’t leaking into the coolant so I’m thinking I have a bad valve on the #5 cylinder or something along those lines. We will see with the test. I’m not sure what to do at this point because there aren’t any shops in my area that will work on a ‘94 and this is probably a bigger job than I can handle at the moment.
