- Thread starter
- #21
All toyota hoses including the PHH (not many use it but I heard Slee does), got all the part numbers from a previous thread and Wit’s End...
Replaced the pair valve and it runs much better and the motor is much quieter and even more smoother, RPM’s down to 850 now and CEL went away... but then code 25 came back a couple weeks later. The reed valve definitely needed to be replaced. So at this point, I got rid of the 25/26 code combo and vacuum leaks seem to be solved (PAIR valve S hose cracked, replaced with Tacoma rad hose) however it still will not pass emissions, it actually went way up! I used Red Heet, and Lucas Injector cleaner (should have used BG 44k, and will after I go though a tank or 2) and I’m at a loss. No vacuum leaks and the TPS is literally perfect, I just don’t get how HC’s went up. Last things left on the list are loose ground and ECU.
Yeah I disconnected the brake booster hose and put it in there and the smoke traveled through all the hoses and came out the air intake inside the passenger fender. It won't hurt anything as far as I know (professional shops use mineral oil like this), but the smoke made my garage stink bad for a week or two so I'm going to try it outside next time...would you just plug that baby into the evap line like in the video? I was simply trying to check vacuum by killing the motor through the EGR prior to replacing it. Also, pumping in baby oil smoke won’t do something stupid like mess something sensitive up like a VAF right?
Just as an FYI to other mud members who read this. O2 sensors are a wear item, their switching response starts to slow with thousands of miles of use, and as they get dirty. Even though they may still test okay, they should still be replaced periodicity as part of a good maintenance program. Some car manufactures use to recommend O2 sensors be replaced in as few as 30,000 miles, others recommended 60,000 miles, but that all depended on the type (single wire, 2 wire, or 4 wire) of O2 sensor that was installed.my o2’s tested fine too but were over 10 years old so I ended up buying some new ones
I think smoke coming out the EGR is normal, it did on mine and I just ignored that. You cannot have the engine running. Are you using a few psi or so from a compressor to help flow the smoke?So I put the smoke machine together, thank you for the direction… I hooked it up to the booster hose and smoke began pouring out of the vacuum modulator a few minutes later. I just wanted to check whether the vehicle should be on or off during testing though because I thought it vents through the modulator with the motor off? Just want to confirm what the procedure is to smoke test our 80’s…
Yes, I have it hooked to my compressor so it is definitely pushing the smoke through but the smoke is leaking from the blue modulator next to the EGR and not the EGR itself.I think smoke coming out the EGR is normal, it did on mine and I just ignored that. You cannot have the engine running. Are you using a few psi or so from a compressor to help flow the smoke?
Pretty sure that is normal, do you see any other leaks? Has the smoke made it all the way to the air intake in the passenger fender well? The leaks may be small, using a bright flashlight with low ambient light helps. You could also put smoke up the tail pipe to check for exhaust leaks. If leaks are near the O2 sensor, can mess up the O2 readings.Yes, I have it hooked to my compressor so it is definitely pushing the smoke through but the smoke is leaking from the blue modulator next to the EGR and not the EGR itself.
