I am having an issue passing emissions, and I’ve done the basics like vacuum lines, tune up, oil change, charcoal canister, etc. Very easy emissions testing in NM but at this point, I’m thinking it’s the Cats but don’t want to throw money at it if I don’t have to. The o2 sensors were replaced under the recall in 2008, and test fine, so I’m at a loss. I have NO CEL and after the all OEM tune up, it purrs and runs smoothly BUT still has a high idle (a vacuum line under the intake manifold was missing and i replaced it but it still did not resolve the high idle) and I’m planning to do the distributor O-ring for good measure, so I will definitely check the timing next to see if that helps the high idle. Bottom line, should I replace the cats? I was thinking a single magnaflow 2 in 1 out (2.5in) and do a Borla muffler? Any thoughts?
also, j/k. BTW, I just called the local dealership to see about getting my distributor o-ring done by them so THEY can adjust the timing and the quote was $192 FOR LABOR! Ridiculous!
