- Thread starter
- #61
I drive it here and there but lately I’ve been avoiding driving it to prevent further damage, mainly because until recently I wasn’t sure what was going on around the lean condition/code 25 -can I drive it on a couple hour trip on only 5 cylinders safely? Do I disconnect the injector or anything, or just let it ride? I drove it on a 100 mile/2 hour round trip recently and it did 80mph on 35’s up the hill to Santa Fe (which is a big “hill” at elevation) but the trip prior, I could feel that cylinder lagging/the intermittent miss and could only do 55-60mph up La Bajada/the “hill”. If you know the “hill”, clearly only a healthy LC motor can do more than 65-70mph up it.
At this point I think it’s a bent valve or a burnt valve because the problem is intermittent and sometimes it runs perfectly and then will have a totally random stumbling idle. The motor only has around 40k miles on it so I don’t think that it’s an issue with carbon buildup and it’s a new Toyota short block because I have receipts from the PO but do not know if they reused the head from the old motor (head gasket failed at around 200k) because it was the previous owner who did the work. It was a shoddy job because when I got it it would stall (but it passed emissions for a several years) and I found out that they reused the sensors from the previous motor and broke a lot of them when they reinstalled the engine (both knock sensors were smashed up but still plugged in, lol). Once I replaced the broken sensors shortly after I bought it, it was perfect for several years and then started doing the code 25/26 combo and here we stand.
) nor do they have time for sending it out for the associated machining. The 2nd shop I took it to said it had 30 PSI in cylinder #5 and told me that I had a burnt valve and that the head gasket seems intact because it’s not leaking air into the coolant (2nd shop that confirmed this). I scoped it and contrary to what the shops are saying, the valve does not look burnt at all, but completely gummed up. The spark plug is also not looking as if it is running lean as a burnt valve would show but I haven’t had time to work on it and would love to do what Dave 2000 recommended previously but have very little time to do anything at the moment. Here’s a scope I took to show the condition of the valves, please chime in if they look like something more than a gummed up valve is wrong…
