Registry 8x Series V8 Swaps
Vehicle Registries
i do not have overheating problem but just can't get over it running at 210 F heaven'S people telling me it is normal
how far back did you move your engine because i do not have that much room between fan and radiator
My motor is about as far back as it can go. I probably have 4 or 5 inches I'm guessing between the water pump pulley nose to the radiator face.
Got the exhaust support brackets done. Seems like it idles smoother. The bracket is bolted to 2 trans pan bolts on each pipe. Just after these brackets are flex pipes.
Working on this one now. Wiring & shifter linkage are the only things that haven’t been ironed out.
Hi I am new here and have been reading alot and I'm overwhelmed with all this. I'm just reaching out to find out who makes a transmission adapter to go from a Chevy 5.3 to my factory 92 auto transmission?
I don’t think anyone does, nor sure you would want to. The adapter goes between the GM transmission & t-case.
You want to keep the GM engine & transmission together if you want an auto. They speak the same language and play well together.
