Check with @cruisermatt for OEM parts needs. He has been a huge help for me in getting a bunch of OEM parts and he’s in FL so shipping is better.
Grab your vin. Then go here: https://partsouq.com/Is this (9091921410) the correct part number for the wire set?
Shoudl I get a new cap as well?
Amazing tool - THANK YOUGrab your vin. Then go here: https://partsouq.com/
You'll be able to find the oem part numbers for everything on your 62.
Give everything a good clean. If the connections are sound, I don't think that changing it out is necessary. Of course, if you have the extra cash... go for it. Check the o-ring and dust gasket too (just did that on my wife's 80... new rubber never hurts).Amazing tool - THANK YOU
Both part #'s I found are correct.
Do you all suggest changing cap also or no need?
Forgive me if this seems basic, but im cleaning by looking or scraping off crud etc, look for cracks on cap, and should I spray or wipe with anything and let dry? I will understand this more I guess when I pull it out.Give everything a good clean. If the connections are sound, I don't think that changing it out is necessary. Of course, if you have the extra cash... go for it. Check the o-ring and dust gasket too (just did that on my wife's 80... new rubber never hurts).
Replacement of wear items is encouraged - rotor and cap; check the resistance of the spark plug wires- if within spec than no need to replace them. It’s only money, right ?Forgive me if this seems basic, but im cleaning by looking or scraping off crud etc, look for cracks on cap, and should I spray or wipe with anything and let dry? I will understand this more I guess when I pull it out.
So... I obviously want to drain the fuel, but I dont have a working battery yet. Is there anyway to tell how much fuel I have to make sure I have enough tray's to catch the old sludge? If there is is 20+ gallons in there I guess I should just make sure I have at least 25 gallons of empty trays/buckets worst case scenario.
welcome 'board this crazy train of the toyotaly insane
Thank you for the formal welcome, I’m sure there are many passerby’s so it takes a little time to be offered a drink round here. Speaking of which I owe you one my friend!@Ballzzz , first off, all these guys have posted up n not one of them scoundrels have given you the official mud welcome so let me look after that short coming![]()
way to get after it misteri'd like to weigh in on spinning the engine over by hand, an old gearhead in my much younger day advised me to turn it thru 2 or 3 complete compression strokes on all cylinders with the plugs in. his theory on this was if they all felt alike, the basic health of the engine should be good. i.e., no burnt valves, or majorly broken rings. he'd found both with that test
if i recall correct, it's a 19mil on the crank pulley bolt.
there is no cure, but the therapy is awesome![]()
Not the best shots at night but I don’t think bad on the frame at least, body is another story.i wanna see how crusty that thing is on the underside
lOl no worries, shes outside at the moment. Thats the goal some rubber that holds air, some fresh gas, a new battery and see if she can purr. If so next step is see if she can limp into the garage lOlIf you fire it up in the garage, be careful of what the tailpipe is pointing at. I started my 60 after sitting nearly 20 years and you would not believe the rat turds, and acorn shells that came flying out. You may have some stuff in your muffler too.
