8274 winch bumper plate mount
lenexa, ks
Looking for a design or a pre made plate to mount a 8274. I have a decent looking bumper, so just want the plate and brackets to secure it to the rig good.
I do have saginaw conversion, so not sure if I need to be offset to a side.
I found this at 4plus. Can't tell the thickness of the material, but this would be it. Anyone use this?
http://www.4plusproducts.com/imgs/product/fj40/backplate8274large.jpg
4PlusProducts | DIY | FJ40 Winch Accessories
I plan to adapt the bumper to lower the 8274 to look like this.
Finally, I have a 8274 that was remote cable operated. Anyone know if I can convert this, or do I need to sell it and buy a normal one?
Generally what I have seen is the plate is welded to the bumper - there aren't brackets to hold the plate to the bumper. I have two bumpers that are designed for winches - one was a dealer option way back in the day and the other is one made by Warn. Both have welded on plates.
I suppose if you have a full tube bumper you could drill holes and bolt the plate to the bumper. Not as clean as welding since you'd have a lot of bolts showing. Wouldn't be my first choice.
Shouldn't be difficult to fab one up and if you can weld or know someone that can weld you are golden. I want to say the plate is 1/4" but will need to confirm later. I can get you dimensions of mine plate also.
@ginmtb Thanks for thoughts...
I plan to weld it on. I am just looking for a premade plate that people use, or a good design. If the 4plus is a good thickness, I will drop the $21 and get it. Just getting lazy -- or have too many projects to do.
Thanks @tornadoalleycruiser ... I sent you an email a little while ago. Let me know who I need to sleep with to grease the wheels....
View attachment 1388514 View attachment 1388515
What kind of bumper is that? I like it a lot!
Anthony
I have 2 bumpers ready to go.
#1 FORMED CHANNEL BUMPER MADE FROM 3/16″ H.R.S. WITH A 1/4″ THICK MOUNTING PLATE FOR A WARN 8274 WINCH AND CUT 45″ IN LENGTH. $85
#2 $125 NEW Front Bumper with Winch Mount for 1958-1984 4x-Series Toyota Land Cruisers
