80 Series Rock Rails by LandCruiserPhil - orange is the new black.....
Here are pics on the LX. As previously stated, for the LX you need to remove the bolts that lay vertically just on the outside of the pinch weld.
If these are not removed the rails will not lay flush against your vehicle.
I "dremeled" the plastic trim that hung on the weld....I cut off about a half of an inch, just shy of the bolt holes that I had previously removed.
As you see from the pics, the new rock rail takes place of the bolts and firmly secures the plastic trim to the underside of the vehicle.
(Also, the plastic trim is also secured from the factory with glue....u could remove all the bolts and never mount the rails and the trim would stay in place)
Other than removing the bolts and dremeling, the install is the same is the LC, I believe.
I painted mine semi-gloss black with Krylon. I applied a couple of layers. The black matches the black of my Slee bumper.
Due to my lack of measuring skills, I ended up pounding on the rails with a rubber mallet in order to secure them into the mounting points.
The paint was unaffected and off course, it didn't affect the rails.
As far as placement of the rails on the pinch weld....on the passenger side, the first one I installed, I didn't properly line up the rail in the front of the vehicle....Keep in mind, the reason the rails flare out in the front, is because the punch weld also flares out.
I was working from the rear of the vehicle forward, and realized this after all the holes were drilled and I couldn't figure out why the rock rail wouldn't lay flat against the weld.
Instead of re-drilling all of my holes 1/2" back, I, as stated above, used my rubber mallet and began tightening the bolts. With a little tightening, the weld bent and flushed up against the rail.
Lesson is, line up the front of the rock rails against the flare in the pinch weld.
As for the driver side, it went smoothly. Again, trim the plastic, remove the bolts, line up with flare, mark your holes, and mount.
The rails are stout, lightweight and a great alternative to spending 1k on ....especially in my case were I rarely see rocks, the few times that I do, I like the thought that I have some protection.
A little word on Phil....after I ordered the rails, Phil sent me a PM and said he wanted to call me and answer any questions and help in anyway with the install. The next day he gave me a ring and we spoke for 36-minutes!! (I looked at my phone as I was hanging up as I was so impressed that he took that much time out of his day to help me.)
The install of the rails took up the first 10 minutes....the next 25 I picked his brain about various cruiser questions/advice.
GREAT customer service!!
Overall I am very happy, glad I bought these, didn't go "unprotected," and I didn't drop 1k.
(Notice the stealthness)
In of the above pics....any "bubbling" chunks, or drips in the pic is water dripping off from the carwash and mud that didn't wash off.
(Prior to wash)
...via IH8MUD app
How do we order these? How much for a set shipped to 04055?
And thank you for putting in all the work and making these up!
I got mine on last week, took about half a day of painting and an hour taking my time to get them bolted up. I think these will be the answer to a lot of folks concerns for rocker damage with out having to go with sliders. Painted mine with Rustolium Hammertone they came out sweet, we'll see how the finish holds up.
Close up of the finish.
Turned out nice with that color. Looks great. I alway like paint over powder coat due to the ease of touch ups.
I just did Hole in The Rock Trail and pictured is the closes I could get the rail contact. I had lots of rock contact with the rear bumper and the front but never touched the rails.
Same vehicle with same lift and heavy duty sliders would hit here. Even on the pictured ledge no rail contact.
A few Rock Rail sets still available:cool:
I just did Hole in The Rock Trail and pictured is the closes I could get the rail contact. I had no problems with rock contact with the rear bumper and the front but never touched the rails.
View attachment 896747 View attachment 896748
Your's looks like a well kitted rig! Hope to grab some rock rails once I get the 4X4 Labs rear bumper fabbed up. Cheers!
Finally got around to painting mine today. I was lazy and didn't want to go out and get paint so used a can of Rustoleum flat black BBQ grill paint I found in the garage. If everything goes right I will them installed first of June ready to get tested for two weeks in Colorado.
Finally got around to painting mine today. I was lazy and didn't want to go out and get paint so used a can of Rustoleum flat black BBQ grill paint I found in the garage. If everything goes right I will them installed first of June ready to get tested for two weeks in Colorado. View attachment 896763
Great time of the year to be doing the CO trails. The Rails will serve you well they have seen lots of testing on most all the trails in the Ouray Silverton area.
Great bumper should look like the one on my rig when you are done.:hillbilly:
Phil,
Quick question for you....how low in general, do the sliders hang below the "vitals" that they are protecting.
I was just looking at a 1" body lift and thought that the rails would also raise an inch.
No point in raising the body, if I will lose my protection.
Your thoughts??
...via IH8MUD app
Phil,
Your thoughts??
...via IH8MUD app
Not to avoid your question but why the need for a body lift? The rails are protecting your pinch welds and bottom of rockers now by raising your body this protection will not change.
Sounds like you are looking to mod something :grinpimp:
You are actually 100% correct. I have completed my list of "wants" for the rig....funny, when I bought it a year ago, all I thought I would ever do was tires.
My life feels empty without a new mod to work on....
...via IH8MUD app
...via IH8MUD app
Cool! post your list
