79' carb fan
does anybody have how the carb fan connection goes. Pics and all, in my cruser there is only the carb solenoid cable, but i'm pretty confused with the carb fan.
plug into the harness under the housing. fan is bolted to inner fenderwell.
Solenoid cable?:confused:
please post pics of yours and what you are looking at.
shane
shane
Ok, I'm on vacation, as soon I get back home i'll do that.
I'm not trying to hijack this thread, but I have questions on hooking up the carb fan, too...
When I got my truck it had headers and a Weber carb, so obviously the temp sensor for the carb fan was missing. I also unhooked the wiring from the fan and control module because it seemed to be dragging the battery down. I would like to get the fan working again. Is there any info on adding the pieces back to make it wor, preferably by thermostat? If all else fails, I will probably put in a manual switch.
Thanks!
I'm not sure I understand your question(fj40ec). Several things have to happen in order for the fan to come on. The fan is connected a timer module. located inside the cab by the heater area. First thing: the thermister(one wire in series goes to it) is activated once the temperture on manifold gets hot enough. Secondly, the module looks for an "OFF" condition at the ignition switch once the vehicle's engine is hot/warm. At that point the timer will activate the carb fan relay( located near the timer module). When the selonoid is energized the contacts will turn on the carb fan. I have never timed it.
Things to look for if the carb fan not working. 1. Thermister, I call it a thermister but I'm not sure what toyota calls it. 2. The timer module could be bad or you have to resolder the solder joints at the connections. This is usually the case. 3. You may have bad relay. Assuming the fan works and wiring is correct.
Pretty good summary...
I'd first hotwire the fan, see if it works. Next make sure the temp sensor is hooked up (or even there!). I think you're supposed to ground the sensor wire with the ignition on, then turn it off to test that part. Then you gotta find and test the controller, have fun with that.
That controller has a wire that goes to the voltage regulator (I guess to sense the ignition "off" condition?). When the PO of my piggie switched out the alternator for an internally-regulated GM alt, my controller was disabled. Took me FOREVER to figure that out!
I finally wired in an adjustable temp. radiator fan controller for mine...
A sort of related question on the carb fan issue if I may.
Last night a cruiser buddy and I were discussing carb fans. I have a 78 FJ40 which has been desmogged and have a recent Jim C rebuilt carb. The truck starts and runs great. Is adding a carb fan a good idea? What's the upside or downside? Do guys ever install a carb fan and just turn the darn thing on while doing slow wheeling in the hot summer months? Or should you hook it up right and get it to work with the stock temp sensor/timer module etc?
Thanks!
Max
Thanks!
Max
I have that damned 1976-1977 Kalifirnia thermonuclear reactor exhaust manifold, which gets things so hot it cracks intake manifolds over time (you can literally see it glowing red at night...) so I NEED that fan. I think the cooling fan was an attempt to mitigate the extra heat generated by all the smog crap. Mine now works when the sensor reaches a pre-set temperature, whether the ignition is on or off. If yours runs good without it, I wouldn't bother. If it came with one, why not use it?
clueless here, but do those things really make a difference? seems like a strange concept, but maybe toyota came up with a simple stupid way of keeping the carb cooler by just blowing air over it? chevys or fords or "whatevers" have carbs mounted in the middle of the big V8 engine and they don't have "carb fans". i am sure there are some of you cruiser geeks, (i am just a poser) that know all about this concept, so please fire away. thanks
Thanks!
The temp sensor mounts to the intake manifold and there was no reason for the PO to remove it. I have headers and the fan works fine. The purpose of the fan is to avoid vapor lock in mostly hot weather areas. When I bought my 78 40 18 years ago it did not work and I had a heck of a time trying to restart after letting it sit hot in the summer. After fixing the electronics it has never had that issue again. It comes on after I turn off the engine and runs till the thermocouple output measures an acceptable temperature which triggers the electronics to turn off.
Excellent question! I was just thinking out loud. Lot of guys have variables when it comes to the carb question: stock carbs, stock emissions, desmogged, electric fuel pumps etc. I am not sure if my rig came with a carb fan or not. I have a box of stock emissions stuff that that the previous owner stashed in a box. I will have to check. My friend has had some instances when his fuel in the carb has gotten too hot. He as a 74 Fj40 with a later 2F and an electric fuel pump. We were just wondering if a carb fan (manually wired and controlled for hot conditions) would help or not.
Max
Max
With a stock carburetor you always run the risk of vapor lock in hot weather, which is the fuel boiling in the carburetor or supply line. Toyota did not put that fan in because they thought it was a neat idea. An electric pump will not cure this problem if you have it. I would think that people that have removed the fuel return line would have more issues with vapor lock than those that still have it hooked up. The issues with vapor lock and aftermarket carburetors on a Landcruiser is not one I have experience with.
I see... I thought it was on the exhaust, so I haven't even looked to see if it is there. I don't suppose you could upload a pic of it so I know what I'm looking for? Or maybe describe where it is and what it looks like?
Thanks for the info!
Sorry for the focus issues. It was hard to get this photo. You can see the bracket and the two mounting bolts. That copper looking mount on the bracket is the thermocouple which has a one wire output with a connector that mates to a connector under the hood which goes to the control board inside the cab on the fire wall which uses that input to control power to the fan.
Here's another, though it's from a 62, but about the same as my 55. The sensor is almost right in the middle of the photo.
I just remembered, too, that there's an in-line fuse to the fan right near the fan controller inside the cab. Seems to cause a lot of people trouble.
I got most of my troubleshooting info from the 60-62 forum...
attachment.php
attachment.php
I think I get the idea where to look. I'll check this evening to see if it is there. If not, I'll try to scrounge one up to see if I can get the thing going. Like I mentioned earlier, I had a problem with the circuit draining my battery that I need to work out if I connect it back up. It may be a bad controller or something shorted to ground.
Thanks a lot for your help!
:cheers:
Nomis said:
Any idea where the control board is located inside the cab?
It should be right next to the heater on the driver's side up on a bracket on the firewall (if it's the same as my '79). It's a black box a little bigger than a cassette tape with a rectangular hole for the connector on the large face near one end.
I'm sorry I don't have a picture, but it should be pretty easy to find.
HTH
HTH
Mine looks like this ('77). Don't know if there were changes over the years or not:
