- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,834
Would this be the right booster?
Dual Diaphragm Disc Brake Booster for Land Cruiser FJ40 FJ55 FJ60
Brand new dual diaphragm brake booster for 10/'75 and later Land Cruiser FJ40, FJ45, FJ55, and BJ40 with disc brakes. Also works for: Any year FJ40 that has undergone a disc brake conversion. '81 to '87 FJ60 This plug and play replacement unit is designed to work with your existing Toyota...www.cityracerllc.com
And this the right MC?
OEM Brake Master Cylinder for '81 to '85 Land Cruiser FJ40 BJ42 FJ60 BJ60
Brake master cylinder for the following models with front disc brake: 8/80-10/85 Toyota Land Cruiser FJ40, BJ428/80-4/85 Toyota Land Cruiser FJ608/80-10/85 Toyota Land Cruiser BJ608/80-11/84 HJ60OEM part numbers: 47201-60120, 47201-60130, 47201-60210, 47201-60220 Made in Japan by OE manufacturer...www.cityracerllc.com
Or this one, since you said "dual"?
OEM Brake Master Cylinder for '76 to '80 Land Cruiser FJ40 BJ40 FJ55
Discontinued. Please substitute with either Option A or Option B. Brake master cylinder for 9/'75 to 7/'80 Toyota Land Cruiser FJ40 FJ55 BJ40 with front disc and rear drum brakes. Part number 47201-60050. Made in Japan by OE manufacturer ADVICS (previously branded under AISIN). Note: If your...www.cityracerllc.com
Always find it interesting everybody says you need to get rid of the old single circuit brake system because is a line broke or wheel cylinder failed you would lose all brake. 8/80 with a single reservoir one circuits fails the reservoir empties and neither circuit works. Only difference is you get a light on the dash. Major failure like a rubber line being cut like the case of an old 45LV years ago by the time the light goes on the brakes are gone. Years ago bought a disc brake axle, master cylinder and dual brake lines running to right side frame rail for my 68 FJ40. Decided well adjusted drum brakes on stock setup work fine and not worth the hassle of upgrading to disc brake axle up front.
