Ah, so it seems Euro/Scandinavian only still. Bummer, that would've been something I would've been happy to be wrong about.Spain, France , Switzerland Netherlands to name some country's.
Would still love to have one though that's for sure.....
Yeah not sure how far back the liner was expected to go.Was that at Maarten’s? Looked like he had some wild stuff.
Anyway, here’s what I’m talking about with the back corners in a 6x. There’s a 45* angle at the base of the D pillar on the inside. I’ve exaggerated a little with the red lines obviously.
I also just realized this may better suited for the available 6x parts thread.I found this radiator shutter on Amayama while taking a deep dive into finding parts that may be part of the cold spec or Snow Version package (thanks @ToyotaMatt for inspiring the search!) View attachment 3208409
It shows available, but Amayama has canceled orders on me before and then changing the availability. The mounting hardware is NLA.
Toyota never sold the HJ61 in Sweden .
Only high roof V (5 seater) and GX (8 seater) spec HJ60.
Check out this webside canaryislandrover.com
Many low roof HJ61 with all the goodies.
For hanging on to if you were riding in the back??!!Gate bar only offered in 1981 (1982?). It bolted to the drop gate. This is the only one I've seen and it was on the 1981 parts rig that I picked up years ago.
It may not actually be available. Order it and see! Those websites often say they can get it and cancel later. Such a tease.I also just realized this may better suited for the available 6x parts thread.
From Finnish point of view rear sway bar mounts are almost impossible to find in good non rusted state. So I made them myself.
Not 60-series specific but original "cut to shape" Toyota rubber floor mats.
Refurbished radiator screen. These are almost all seized and the vinyl is perished in Finnish climate and salty roads. The reason for it is a steel axle that goes through aluminium end caps. There is only a simple hole in the end cap and it gets corroded and seized. It is simply to pick a part and make it free again. In the same picture is also a new oem radiator that should be nla. I bought the second last one that could be sourced by Finnish dealers.
I don´t know if this is just some euro-spec thing but power outlet for continous and ignition lock controlled 24V.
A pic of the older dash with diff lock lights were posted earlier. Here is the late model dash with same lights. Also a original Toyota C-Cassette tray. Not 60 series part, it is for some newer Toyota models Avensis, Celica, etc. but with small mods got it fixed in 60 dash.
In Finland this late model PTO winch is quite rare. What I have learned this model spins in different direction than the older ones. So no need for the notch in the front bumper. Also this has 15mm lower roller fairlead than the older ones. This winch model has been available with square headlights from late 1987 to 1990. during this time HJ60 models was sold mostly for the goverment and HJ61 to civil owners. HJ61 did not come with winch so this model winch is much less on the market than the older one sold from 1982 to early 1987. Also seen in the picture is quite rare license plate holder. I have never seen one before. Also this HJ60 front bumper is more rare than HJ61 bumper. HJ60 bumper has holes for the plate holder, fairlead bolts and not a cutout for tow hook. Late models also have the pto drive shaft with two support bearings, early models has only one bearing so it is also quite rare because the same reasons that the whole late model winch.
Last picture shows bezels for the rear fog lights. They are modeled by me and 3d-printed. A friend has a nos original part but only for one side. Same picture shows small steps for the split-bumper. Those steps has been nla for at least 7 years. I managed to find nos ones from ebay about 5-6 years ago. Also this side bumper I managed to find nos. It´s original color was for round headlight bumper.
Nos rear view mirror and cover for HJ60. It is nla but FJ62 mirror seems to be available. Don´t know the differences. The rubber stud is old in this picture.
And last. Not nos but not driven spare tire.
I don´t know if these fit this topic but they are some things I am exited about.
Added numbers of those I know or found in the internet.your on the right path here ........
all you need to do now is assign the correct OEM part # to each specific part you mention , like your late modle dash's
snappy call out # 81850 " diff lock lights " indicator box![]()
I have wondered what those small studs are for. Now I know.How about this ?
HJ60 air cleaner warning sensor +indicator light.
Next one,
Cold spec HJ60 Rad screen installed on my HJ61. The 12HT needs it more then the 2H.
I found only new lights but not the whole assembly with brackets. Wow!
This would be nice for smoothing the agricultural ride of an 60 seriesSeat Suspension in HJ60,
Oh my god, I want that Country Cruisin' tape so bad. I have a cassette deck in my 60, so it's just a matter of tracking one down. I'm sure it will be easy haha.![]()
I believe you could get these casettes from the dealer when bying a car or at some test drive events of new models.
As long as you play it on a factory cassette deck. Here's mine, from my HJ60. I wish I had taken a photo of it when I removed it a while back, but there is a factory diagram on the top of the cassette deck on how to connect to the radio. There is a harness that plugs into the back of each to connect them.Oh my god, I want that Country Cruisin' tape so bad. I have a cassette deck in my 60, so it's just a matter of tracking one down. I'm sure it will be easy haha.
Now those are some amazing pieces!From Finnish point of view rear sway bar mounts #48825-60031 are almost impossible to find in good non rusted state. So I made them myself.
Refurbished radiator screen #53180-90A01 and mounts #53188-90A00 and #53189-90A00. These are almost all seized and the vinyl is perished in Finnish climate and salty roads. The reason for it is a steel axle that goes through aluminium end caps. There is only a simple hole in the end cap and it gets corroded and seized. It is simply to pick a part and make it free again. In the same picture is also a new oem radiator that should be nla. I bought the second last one that could be sourced by Finnish dealers.
I don´t know if this is just some euro-spec thing but power outlet for continous and ignition lock controlled 24V #82610-90K03.
A pic of the older dash with diff lock lights were posted earlier. Here is the late model dash with same lights #81850-90A13. Also a original Toyota C-Cassette tray #PZ437-9032-00. Not 60 series part, it is for some newer Toyota models Avensis, Celica, etc. but with small mods got it fixed in 60 dash.
In Finland this late model PTO winch #38110-60140 is quite rare. What I have learned this model spins in different direction than the older ones. So no need for the notch in the front bumper. Also this has 15mm lower roller fairlead than the older ones. This winch model has been available with square headlights from late 1987 to 1990. during this time HJ60 models was sold mostly for the goverment and HJ61 to civil owners. HJ61 did not come with winch so this model winch is much less on the market than the older one sold from 1982 to early 1987. Also seen in the picture is quite rare license plate holder #75111-60030. I have never seen one before. Also this HJ60 front bumper is more rare than HJ61 bumper. HJ60 bumper has holes for the plate holder, fairlead bolts and not a cutout for tow hook. Late models also have the pto drive shaft with two support bearings #37602-60210, early models has only one bearing so it is also quite rare because the same reasons that the whole late model winch.
Last picture shows bezels for the rear fog lights #81483-90A00 and #81484-90A00. They are modeled by me and 3d-printed. A friend has a nos original part but only for one side. Same picture shows small steps for the split-bumper #52185-60020 and #52186-60010. Those steps has been nla for at least 7 years. I managed to find nos ones from ebay about 5-6 years ago. Also this side bumper I managed to find nos. It´s original color was for round headlight bumper.
Nos rear view mirror #87810-90A06 and cover #87834-14011-28 for HJ60. It is nla but FJ62 mirror seems to be available. Don´t know the differences. The rubber stud is old in this picture.
We need audio for all of these now!I got way too exiceted about this thread. Here is something more. Not 60 related, but close.
Toyota music casettes from 1985-1990.
This is quite cool.
Fantastic collection!
