What's the destination?Ha, they just look big in picture. 4, 2 gal cans.
I believe he’s headed to Solid Axle Summit in Ouray/Silverton/Telluride area.What's the destination?
Safe travels! @JTU
Lower RPMs not spinng the fan clutch up as well?
@Elbert getting close to taking a spin in it.
Mine will also hit close to 210. This is running 75mph with ac full blast with a 4spd on the way to Talladega this summer.@JTU my Pig with H55 is getting to 210 in 5th cruising at 70. So does Dustin’s with 4 speed.
Mine drips to 195 on backroads going slower.
Peel out.
Texas-New Mexico-Arizona heat this week, often in the low 100s. Running 65-70 mph on interstate, always 5th gear and water temp always under 200 F. This reading from an Autometer gauge. Cooling system stock except for the fan clutch that is for a 3FE 80 series.
Where you do you have the sensor ran? @wngrog and I are running ours in the rear block drain. When I had mine in the thermo housing I got lower readings.
@maxbob002 is running a mechanical gauge. Where do you have yours ran?
