6.6 Duramax conversion question
Knoxville, TN
Will the stock transmission handle the power? 300hp and 500 pounds of torque??
I just bought a salvage 2004 Chevy truck and didn't know if the stock tranny would work or If I should try to put the Allison in fj60.
Ill try to get some photos as this build goes along...
Thoughts...
I've been running my stock tranny behind a 383 chevy small block for a while now without a problem (for the tranny). I can't say its actually 500/300 but I'm sure its not too far off from that. Although . . . Allisons are nice trannies . . .
Talk to Kurt at CruiserOutfitters, he's been a big help to me. For both parts and advice.
you gonna run a rack and pinion for steering? or full ram? otherwise the steering linkage will be in the way of the engine...
If that allison is an overdrive then don't think twice about slapping it in there. You'll want OD running a diesel if you see any time on the freeway, you'll be happier. Sounds like you got the whole truck which will be a big help since you've got all the wiring and sensors already hooked up. Is the donor 4wd?
Options for drivetrain:
Run the allison and either find a transfer case that mates to it and run a centered rear axle if necessary or figure out how to mate the splitcase to that allison. Don't forget about doublers offering more options for mating things together. You'll have to do the research and may have to make something fit on your own but you should be able to figure something out. With that much torque and depending on your setup (big tires, lift, small tires, towing) it might be a good idea to step-up in rear axle strength. 31 spline ford 9-inchers have lots of support unlike the cruiser rears (really only the poly performance option) and are strong. Or there is the axle that is on your donor. What is the intended use for this rig? You'll need to know what you want so you'll have a direction to aim for.
Sounds like this project can get out of hand pretty quick so I hope you have a healthy budget planned :D. Look forward to the build-up.
anything less than the allison would be short changing the duramax. If it were me I'd swap the whole drivetrain over and put a 60 up front.
2nd option would be to use a centered rear & the duramax t-case.
Its a big drivetrain so I hope you have a large shoehorn. that being said, I'm sure it possbile. I was tempted to do a Dmax and 4l80e (marginal) instead of my stroker.
I don't think a stock FJ trans can survive behind a duramax. I would run the GM trans and figure out how to modify from that point. Don't know if you have the room for that?
We have put a duramax where it didn't belong (01 3/4 Suburban) and made it look factory. I'm sure you will need quite a bit of body lift or serious tunnel/tranny hump modifications to get the DMax in a 60 series. It wouldn't fit my purposes but it can be done and might be fun. Run the Allison for sure but I think the np263xhd transmission is a big heavy POS compared to your options. Think range box and split case or Atlas/Stak etc. I'd think for actually wheeling multiple gear ratios would be very handy with the DMax in order to keep it in a happy power band and keep the torque converter from working to hard.
For the record, all Chevys with Duramax engines and Allisons run 3.73 gears and have no problem at all with massive trailers and warp speed, especially with a chip. If you're doing a Land Cruiser with that much poop, you will most certainly want to retain the stock gear ratio. I'd keep the Allison if at all possible and get some burly rear axle.
For the record, all (NON DUALLY OR SPECIAL ORDER 3500 SRW) Chevys with Duramax engines and Allisons run 3.73 gears and have no problem at all with massive trailers and warp speed, especially with a chip. If you're doing a Land Cruiser with that much poop, you will most certainly want to retain the stock gear ratio. I'd keep the Allison if at all possible and get some burly rear axle.
Just made a slight correction.
Thanks! My neighbor has one of these, he also owns a transmission shop. He claims to have NEVER rebuilt an Allison except for one where to owner forced the incorrect filter onto it which stopped fluid flow. His has a cold air intake with a K&N and a chip. It damn near ripped my head off. Incidentaly, he burns a mix of 1/2 deisel fuel and 1/2 filtered, used transmission fluid since he has a never ending supply of it. Pretty cool!
I thought the tranny by itself can handle the power .. but not the clutch .. ( not sure if centerforce or some other option can aply here )
Bringing this back to the top....did this conversion ever take place?
I would say to just run your stock tranny, once you get the chevy tranny you will want the TC the drive lines, the axles and pretty soon it will be more chevy than yota you would be like lehi guy!!!!!! hahahahaha
Interesting.
I wonder why there are no pics of the engine bay in that auction. :confused:.
It looks like they may have swapped in the GM axles, too.
Is that a rear air conditioning unit?
I don't know if it was done by the person above, but check it out:
Toyota : Land Cruiser: eBay Motors (item 130394837654 end time Jun-02-10 08:27:49 PDT)
This is an entire duramax frame, chassis, axles and drivetrain with a 62 body on it.
Not a 62, with a duramax motor swapped in.....
Wow! Looking at it again, it makes sense. Got that fatso front bumper on there. Amazing project!
That is quite possibly the ugliest body swap I have seen (next to a Monte Carlo body on a truck frame).
Horrid
