- Thread starter
- #121
I now see why so many guys attach sheet metal to tube frames, though I've no intentions of traveling that path.
There's a lot to consider from various aspects, but, at some point, I'd imagine the engineers calculated load in a roll inverted scenario and based the load capabilities on all 8 pillars being present.
The rear corners on the Pigs are a structural, integral component to the overall stability in a front to back and side to side, as it probably it is in all vehicles, but it "looks" like the majority of rigidity comes from the C & D pillars.....both of which I'm proposing to remove.
The roof skin provides very little structural integrity, which is odd. The roof support rail that circumvents all 8 pillars is stout, but I find it odd that there's no side to side support structure of merit, between the B&C pillars, themselves, but claim nothing more than pignorance.
So, what I was thinking was to increase the structural rigidity of the rocker, reinforce and enlarge the B pillar, with internal structure that "should" afford similar integrity to the 90 degree rear corners, then reinforce the roof channel for B pillar to B pillar, then cross bracing (in an x) from B to A.
I know I keep going back to this pic, but similar to the pillar shown here:
The issue with fabbing similar is the inherent curvature from the rocker to the roof support. For the purpose of complexity, 'cause "simple" isn't synonymous with any of my lofty ambitions, thinking an internal subframe, damn near like a wing, that the steel can be wrapped to, to recreate the curves, but hope to have a complete pillar from the '71 out to further investigate.
Thinking a similar internal support structure may be necessary on the rear quarters, since chopping off all cross bracing from side to side, leaving only the tailgate between the now shortened D pillars.
Used to employee a CAD detailer that returned to oil and gas when the chit hit the fan on '09. He's going to input (because I never learned how to utilize all the features of AutoCad, therefore dependent upon) what we "know" from the drawings I've accumulated, but it really isn't going to be the blue print for success, because there's not enough data to work with.
Here's the thing, folks.
I don't want any part of a POS, period. If it's gonna be done, it has to be done right.....but determine what's "right" when you're not an automotive engineer proves very difficult.
You'd think that a body as square as a Pig would be easy to even conceptualize good looking lines, but guess I don't have an eye for it, or am overtly critical, because I can't seem to find a good way to do it, and it not look like a ghetto fabbed, hack job.
I've never modified anything but a quad, before getting into Toyota's a few years back, but I've learned that Toyota has a reason for everything, regardless if it's visible to the uneducated eye.
For instance, I've cussed Toyota 10-11 times for the monstrosities of body mounts they used on the FJC, as I chopped them off of others to run tires that fit the fat girls body, never understanding "why" they had to be as long and boxy as they are.
Then, I saw this....
and it became clear in an instance.
Now, I lose sleep over those I've removed and instances similar are why I'm thoroughly exploring every option on every damn thing I do, now.
...laughing with; not at...HAHAHA, but they give you chit over the word pig on a license plate
