Worth a shot. I sent them a message.Try asking Orto.
Ask Orto - Technical Questions and Answers
Orto is our resident technical automatic transmission expert.automatictransmission.com.au
FWIW, I've seen stored codes via Techstream that won't pull up with my generic Bluetooth OBDII reader, likely for the reason @Bisho states.I'm not sure how they compare. The ScanGauge, to my knowledge, should read any codes that come up in real time. But maybe there's another layer of diagnostics that isn't read through the OBD port?
I don't have TechStream. But I have found something here about jumping ports on the diagnostic module (in the engine bay I believe?) to trigger light flashing on the cluster sort of like OBD1 would have done.
A lot of these procedures relate to solenoids, which I feel like you (most likely) ruled out when you swapped transmissions.ill look in the traction control section and see if I can find anything related to it being able to disable 5th gear - according to the transmission section, that's not a factor.
For sure. Apologies for the odd mix of portrait and landscape - wasn't paying enough attention to how my phone thought it was oriented.Super helpful, thank you! I will send this to the shop. I'm not sure if they'll have Toyota specific diagnostic tools but worth a shot. I imagine this may need to go to the dealer soon.
Ugh...
Dude, thank you so much for this! The tech has mentioned the possibility of a break or failure in any of the wiring or connectors and was going to start looking through that on Monday. I will send this along to him.
Hahaha - you're not entirely wrong. If it works right the first time it's easy... If not, it can get annoying quick.To Techstream in 5 minutes you must first read "TechStream in 5 Minutes", which takes about a hundred hours.
Try asking Orto.
Hey buddy, thank you for your inquiry.
We would suggest putting a scan tool on the vehicle and seeing if the TCM is commanding 5th gear, if it isn’t commanding 5th gear we recommend clearing any other codes the vehicle may have (transmission related or not) as these can also cause this to happen.
If the issue persists then you may have a faulty TCM
Cheers![]()
Hmmm. The wire harness that runs to the transmission comes straight from the ECM. Pretty sure the ECM does all the control stuff for the transmission in a 100 series - looks like the 80 series had a separate TCM.This is what I heard back from them:
What's so odd is that there are still no codes showing. Patch is going to loan me his tech steam laptop to dig in to this further. I also have a "transmission relay controlmodule" on order, which is all I can find when searching TCM (besides the ABS/TRAC/VSC module, also on order).
