4Runner wiper upgrade...couple questions
^^^ Check the connector for corrosion and how much voltage is going into the motor at high speed, you might want to try and jump it straight to the battery and see if the motor speeds up. @Stridertexas
I just wanted to confirm the year of 4Runner from which the wiper arms come.
Are the from a 96 4Runner?
Txs
Chris
Great. Thank you. I found a 96
Mine are from a 96 and work perfectly. Like @4Cruisers said, pretty much any from a late 2nd Gen 4runner should be fine (96-00).
Ok, just picked up 6 left handers from 96-00 4runnets at a you pick 40 miles from my house .
So, i have 4 arms, with nuts, and dust caps. Still all in really good condition.
Will take detailed picks when i get home.
PM me if interested in one of the two pair remaining . not sure what to charge for them, but i know what they are new, and that's insane. That's what I'm here .
I hate auto correct .4runners*
You know what I meant to say .
They are installed .When you remove your old arm, leave the rubber boot that's on the spindle in place. When you slide the 4runner arm on it will be a nice snug fit .
The new nut which holds the arm to the spindle is the same thread pattern, and the metal washer is slightly larger in dia which is nice.
The dust caps click right on .
Below will be a picture of the 17" whippers I installed prior to attaching the new arm. Purchased them at O'Reilly's, $21 per.
Pics of remain 2 pairs of left hand arms, with dust covers, and a pic of truck . they just need a little cleaning up.
They worked great. Wish we had heavy rain here in SOCAL to really test them.
On truck. Top pic is of both 4Runner arms. 17” blades.
Bottom pic is one of each.
Pics and part #'s for front wipers w/ caps and rear wiper
Can you use the original nut? Easy to find arms but none seem to come with nuts.
I’ll se
Yes you can. Same size threads, see my pic showing different size of metal washer . top 4 are from 4runner, bottom 2 are my 60's original .
Anyone who's interested, I'll sell a pair of two left handed arms for $45, encluding 2 nuts and 2 dust covers. Shipping is included to all lower 48 .
Cheers .
Chris .
