40 series general tech and classifieds
Spotted in Funroe
...via IH8MUD app
I wouldn't be caught dead in that color :eek:
Lash, did you ever get your radio issue figured out? This might help if your fuse block is still used.
Wow. That's good stuff Jeff!
Fortunately I found in OEM plug that is working great.
Lash,
I finally got to installing the transmission and transfer case i got a few months back.
Did some other upgrades while I had the truck on stands.
Replaced the transmission, transfer case, tie rod ends, steering box (no power), new exhaust, muffler and exhaust manifold gasket, and added a few parts back to the truck that were missing before, a rear heater, the skid and splash plates, a carburetor cooling fan and a specially made switch plate to transfer winch control into the cab, a new trollhole carburetor (while I am rebuilding my AISIN) and a set of new original 78 front seats with headrests. Last was the addition of a set of (still not painted) barn doors in the back while the hard top is off. I had been slowly acquiring and refurbishing all the parts for this update for now over a year. It was time to actually install all of these upgrades. Next in line are to replace the front axle seals and rebuild the warn hubs.
So I think I am getting closer to actually trust the main structure of this truck.
With the "new" transmission and transfer case" it sounds much nicer. I replaced all the seals in the transfer case before I put it in.
And I now actually have a working parking brake. No more gear oil leaking out!
I wired a secondary fuse panel on the passenger firewall for the extra switch plate and took it from the original fuse panel constant hot. Works well.
Lookin good!
You have done some quality work.
well, bumper and shackles are not stock ;)
72, 73?
Historic Mississippi Truck.
William Gates/Parker Graves/Patrick Hall/and now my '75 40 gets new shoes...
