FYI, what little off-road low-range gearing you think you might have had in the past will completely disappear when you add 35's.
That said, 35's look pimp.
IIRC, 80 series wheels have 4.5" backspacing. I think they look pretty good on a 40.I have been running 1.5" spacers for almost three years with no adverse effects. Wheel backspacing is between 3.5 & 3.75". With the spacers my effective backspacing is 2.25 - 2.5". If you can find wheels with that backspacing, no spacers needed....
What size are your AT's?Guess I'm selling my BFG ATs. I'm ready for some big tires.
http://www.tirerack.com/tires/tires...KM2RWLV2&vehicleSearch=false&fromCompare1=yes
I'm sure I will be in market for a georg built Orion in a few months. Didn't Lash use stock gearing with large tires for a long time?
IIRC, 80 series wheels have 4.5" backspacing. I think they look pretty good on a 40. What size are your AT's?
Serious wheeling with 35s and stock gearing requires more beating/bouncing/bumping than I liked. 99% sure my broken spring center pin at Moab was the result of how hard I was having to pound on it to keep up. I also chose an H41 transmission for the lower first gear. This lower first helps on and off road with 35s. It might even be low enough for 37s some day?? Next step for me is a front ARB locker and stronger axles, birfs, and hubs.
You would have to use 1" spacers on 80 wheels just to get back to OEM wheel backspacing. It would take 2.25"+ spacers to get as wide as most with 80 series wheels. Pretty sure J & SRob have around 2" effective backspacing and their tires are 13.50 width. Mine are puny 35 x 12.50. I do like the look of painted 80 wheels on a 40 though.
35" with 1.5" spacers all around.
Get Georg to start building the Orion.
http://www.budbuilt.com/new/cruiser_parts.html Anybody ever seen these or something like it installed. My corner panels are crap and the DP looks bad too. My fab guy mentioned using these. What do you guys think. I will probably never make my truck pretty so thought this might be cheap way to clean it up a bit. Having family cage project start next week using the metal tech front that I won at the crawl a few years back. Anybody got any ideas? We are thinking of tying metal tech into middle hoop but redoing the rear part of cage.
OEM main hoop will not hold up to much. Ask me how I know. Do the work right the first time and as safe as possible - Full MT Family Cage. Sell the Stock roll bar to someone doing a resto.
