Busy day.
Cleaned up a bunch of wiring.
wired and mounted the switch for the delete plate door.
mounted the speakers.
mounted the vent door cable knob.
I had a later wiper switch because it has a two speed motor. So wire it up for a single speed switch, or have the wrong knob on it. I need both, so I cut the 6mm threaded insert out of the later knob, turned it down and epoxied it into the early knob. Now it pulls rather than turns, but it works for a two speed motor and fits into the correct hole in the dash.
found and mounted and wired the plug for the work light.
Mounted the winch motor I got from Tucker. The gear that engages the winch is part of the motor shaft on the Bellevue. The warn replacement gear fits neither the Tucker motor or the winch. I put the shaft in the Tucker motor. it fits well, but it doesn't work. it must be the part that's bad. I chucked the end of the motor shaft into a drill and spooled the winch with cable. I even wired up the winch knowing the motor doesn't work, but it's not like this truck is going to be needing a winch anyway.
Took the steering wheel off and epoxied up the cracks.
installed the door window outside weatherstripping. Left the inner felts in place in the rear. Put in a pair of 40 series felts in the front door. They are too short, but they keep the windows from rattling until I can find something that fits.
And moved my new Baileigh Ironworker into place for it to get wired.
