- Thread starter
- #441
Another day puttering on the LV. It's starting to get a bit frustrating. It's a ways from being done, but it is to the point where it's very drivable, except we've had an epically s***ty winter here in Chicago. I fought with myself all day if I should just drive it a couple of miles to the hardware store for 7/16 bolts for the winch and for some fuel. I finally decided not to. There is tons of salt on the roads from all the snow we've had and no melting cycles to wash any of it off. The Tundra is caked with it and I rinse it off every few days. The LV also has no plates or insurance on it and it would be just perfect to be plowed into by some fool who has the wrong car for the snow.
It also has no heat.
Cleaned up a bunch of wiring in the engine compartment.
Hooked up the horn. I used a foot button since my column is missing too many parts to make that work.
Ran the air lines to the air shocks. I mounted the schreader valves in the corner access panel on the right rear. Seemed better than drilling holes in the floor and won't make carpet fitting weird.
Cleaned out the whole truck.
Ran it for about a half an hour trying to get the fans to turn on. The upper hose outlet where I put the fan switch never got hot enough at idle.
Messed around mounting the Warn Belleview winch. Decided it was too nasty and tore it down. The covers are all sitting in the parts cleaning tank. They were nasty. Sandblasted the drum. Gives me something else to fiddle with.
