- Thread starter
- #21
Thanks, that's good to know. There are no 2:1, 4:1 xfer case options? The Orion is just 4:1 and there's no version of the atlas that will work?
Unless you are only planning on running hard core trails 4:1 is a crappy choice. You will be hating that gearing on most trails.
I run an Orion with a Marlin Toy box, 4:1 for the Orion and 2.48:1 for the toy box. MOST OF THE TIME I never use the Orion low range.
With a 4l60 you can run a 203/splitcase doubler.What are my transfer case options to get a 4:1 (I'd rather do that than lower my differential ratios front and rear) transfer case. This is an 84 LandCruiser with 5.3 vortec, 4l60 and stock transfer case. Since I have the AA adapter the stock xfer case, can I put an Orion in?
203/splitcase is around $500 (I have a brand new one on my shelf for this price), not even close to $2k.4.11 axle gears are common for cruisers and relatively easy to change if you get the whole 3rds. Used $$$ 500 any fj60 in a junk yard will have them. 24 beers labor
4.1 gear set for split case. about $$$ 2000, 12 beers labor.
Black box or doubler. $$$ 2000 + new drive shafts and tranny cross member modification to clear front drive shaft. a kegs worth of labor.
I have spring over with wheel spacers. NOT tippy for an educated driver. I have 4.11's 3b 5 speed. great on hwy. great wheeler. I've been thinking about 4.1 t-case gears for rocks. but...... rocks just end up breaking stuff.
SM420 and an Orion should get you pretty close.Because you hit top gear on the 2wd sections in between the hard parts. It's happened to me, but I don't "hate" it.
That's a nice setup. It baffles me that they don't sell those. I would think they'd sell quite a few. If I had one I'd play around with 10:1 a lot.
Its ... very effective as long as you don't need to run highway speeds without unlocking the hubs.
Good point.fixed
