3rd's
so the bolt pattern on the flange is different, which i was pretty sure it was.
what about the spline count on the pinion, is that the same?
is it as easy as just pulling the pinion flange from one and putting it on the other?
or is it one of those "find that bastard part that has bolt pattern A and spline count B to fit on 3rd member C."
You will need to find fine spline flanges...1979-1984(bolt pattern changed mid-year 1985) and yes, you can swap them right over.....new seal, new stake nut, some red locktite, and you are good to go!
are you changing gears out? or just asking about the carrier itself fitting? if you're getting aftermarket gears, they will be fine spline pinion, so you would use the fj60 pinion flange and either drill out, or use the fj60 slip yoke for the driveshaft also.
He's looking for a swap of the entire diff. I've got a set of 3.7s in my 82 troopie, 68.5 x 60mm pattern but I think the bolt hole size is slightly different, 11mm on the later flange vs. 10mm, does that sound right? Thanks.
instead of trying to track down the stock flanges you need, you could just order up one of these flanges...Iron Pig Offroad has 'em, as well as Marlin, and I'm sure most other places...
Alternatively, couldn't you fit your FJ40 driveshaft with a post-1984 FJ60 driveshaft yoke flange (with attached slip yoke)?
If the shaft/yoke splines are compatible for these driveshafts, a used FJ60 slip yoke w/flange is about half the price (at SOR) of a multi-hole pinion flange.
I'm surprised you can get the slip yoke with flange for less than $17.50 - but keep in mind the SOR handling, shipping, and clear gold plating fee :)
bk
