3B using oil
Toyota disagrees with you saying not to use 20w50 in Tasmania. Toyota engineers who actually designed and tested this also thinks 20w50 is perfectly fine to use down to about -12 degrees C.
Except he's using a full synthetic.. other people have reported ID diesels seems to burn through this stuff at a rate of knots.
I haven noticed that problem with 1HZ or industrial ID engines. My 1HZs would not use a drop until about after about 5-6000klms. My friend says the same about his 1KZ
No healthy engine has a problem with different oil. The type of injection system has no bearing on oil type. They're all aluminium pistons in steel/chrome bores with iron/steel rings.
