- Thread starter
- #101
Both turbos probably could use a rebuild and I plan on changing the larger turbos compressor wheel to a TO4E 46 trim. Considering I made this thing for towing, Id like a slightly smaller little turbo as it doesn't spool as hard as id like in the low rpm range. A rebuild might help with that a bit I guess. Ill most likely swap in a TD04L-6cm or even a TDO4-5cm, but that sounds too small. I'm a bit undecided. Its a lot of work to change the little turbo.
g
g
