- Thread starter
- #141
So I'm getting ready to pull these off my truck as I'm prepping the old gal for sale. I changed out the large turbos exhaust housing to a .63 and noticed boost gains across the rev range. Here are some numbers I've gathered. Timing is retarded as it's not intercooled. Fuel is maxed out. Burns clean unless you stomp on it of idle. Max egts are now 1100f pre turbo. Intercooling would drop egts a lot and would allow much lower boost numbers freeing up some power.
If anyone is interested in buying them let me know as you can take it for a drive before I pull them off. I'm in the Fraser valley.
WOT
1200rpm 5lbs boost
1500rpm 12lbs boost
2000rpm 23lbs boost
2800rpm 33lbs boost
100km/h cruise
800f
14lbs boost
17lbs drive
5th gear Hill climb 110km/h
1100f
30lbs boost
35lbs drive
WOT
1200rpm 5lbs boost
1500rpm 12lbs boost
2000rpm 23lbs boost
2800rpm 33lbs boost
100km/h cruise
800f
14lbs boost
17lbs drive
1100f
30lbs boost
35lbs drive
