You'll find some good information on tuning and troubleshooting your carb here.
agreed - ran one on my Jeep and with larger jets I was able to get it close but it was never optimal. Also, you'll definitely need to get a pressure regulator - they are very sensitive and run at very low pressurePlug the vac retard and test to see if it still does it
The 32/36 is too small a carb … you’ll be throwing money away
Thank you @byron. Going through them now.You'll find some good information on tuning and troubleshooting your carb here.
@brian, Not sure what is the difference between new and what I have? Where would the PCV connect? I am assuming it is a single piece of billet aluminum with a PVC connector? Where would I find that? Weber site?those two pc adapters were terrible, if youre going to stick with weber at least get a pc adapter.
Thank you!Yes it is pushed by the fuel pump.. it is the excess fuel beyond which the carb bowl can take. Should flow fine.
Yeah thanks Brian. I thought that as well. Why would I see bubbles in the fuel filter and the glass bowl? The fuel filter is before the fuel pump, so would that mean air is coming in before the fuel pump? I can check that tomorrow.Sounds like the supply line from the tank is pulling air from somewhere....but you would think it would also dribble gas when not running.
Hi Jonny CThat is a vac advance dizzy … did you unplug the vac line and plug it when advancing the timing? Did you advance the time as mentioned earlier ?
What’s your idle at?
Electric choke or cable?
Two filters are unnecessary
How are you checking the float level in the weber? … there is an easy way to… your not removing the top plate each time are you… grab a piece of solid cardboard cut it to a 1/4ish wide strip 6-7” long… you can slide it in the bowls vent if you have the air cleaner off
In the weber thread somebody posted earlier I have a good pic I made of the float level measurement
