Which @PerryParts part number are you running?
AB4F and AB5R. Note the rear are the long travel part #s
+25What offset wheel?
18’s have better aesthetics imo..17’s are lighter, allow for more sidewall, and allow for lighter tires.Method has wheels on sale 25mm offset best for 35” tires. Go 17 or 18”?
You can have lighter tires or lighter wheels (everything being the same models and/or diameters), not both. Either the wheel is bigger, hence heavier, but the tire sidewall is smaller (makes it lighter) or the wheel is smaller (lighter), but the tire sidewall is taller which makes it heavier.18’s have better aesthetics imo..17’s are lighter, allow for more sidewall, and allow for lighter tires.
I don't know what the logic is behind it, but many tires of the same width and diameter (at least as listed by the manufacturers) are heavier in an 18" wheel vs a 17" wheel.You can have lighter tires or lighter wheels (everything being the same models and/or diameters), not both. Either the wheel is bigger, hence heavier, but the tire sidewall is smaller (makes it lighter) or the wheel is smaller (lighter), but the tire sidewall is taller which makes it heavier.
Regarding weight of tire vs rim:
You can look up and compare and contrast…
-size for size the 18” wheel will tend to be heavier. Other than unobtanium/questional load rating volk’s, 28 lbs is as light as it goes w 18’s, vs 24-25 for 17’s unless you go ringless rock warrior, then as low as 21, though they are known to crack.
-size for size the 18” tires will generally be heavier than the 17’s too even though, technically, there may be less rubber. Why? My guess is: If you might visualize the metallic cord of the bead of the tire, that metal part is a circle with an 18” diameter with the 18” tire…and 17” with the 17…which means more metal/weight in the bead of an 18”…and there’s two of those increased metal beads on each tire…and because they’re stretched along a larger area, they likely have to be more stout than the smaller/tighter 17.
Either way, you can look the weights up. 17” tires tend to be lighter, as with wheels.
Wheel/tire weight isn’t the biggest deal, though manufacturers do make a big deal of reducing unsprung weight so it’s not nothing.
18’s to gain
By my research, mostly of teckis300’s threads, 35 is actually the optimum offset for fitting fat tall tires.Method doesn’t have a 17” with 25 offset on sale. They do have 18” on sale with a 25 offset
Or I can buy a 17” with a 35
25 just happens to be more common and available.
If I had to completely redo my wheel and tire package I would be running the 17” method mr705’s on 35 offset. They’re 25 lbs, have bead grip technology, and can be had for relatively low prices when they run sales.
Not bad.im about to pull trigger on 706 17 with 35 off set, they only have 4 but its 200 a wheel
I’m getting a matte black spare same wheel just different color. Wife wants bronze and they have 4Not bad.
It has the bead grip, $200 is a relatively low price, 28 lbs is considered by some to be a lightweight wheel (definitely not overly heavy), offset is right, styling isn’t bad
Too bad you can’t get a 5th and have a fully rotatable spare.
Over the life of your tires, they’ll often lose about 16/32nds of tread on each side…meaning they’ll shrink by 32/32nds…or an inch.I’m getting a matte black spare same wheel just different color. Wife wants bronze and they have 4
So unless you’re rotating your spare, by the end, you’ll have 4 33.5” tires…and a spare 34.5” tire.
If you plan on not having a spare you rotate, you might be better served with a slightly worn 34.1” tire…a used 275 65 20 would be a good option, especially if you’ve already got a 20” oem wheel.
Matte black whees look good on any colored vehicle imo.I have the stock 20" wheels with new tires. I planned to only use the methods while going on adventures. I could do 5 matte black wheels not sure how I feel about that with the Silver lx i have.
Thanks Geoff... possibly a 285/75-17 is the way to go Toyo RT @ 11.3" wide, is what I am thinking but really I need to try one and articulate it.. I would like to keep the RW's since it is a forged wheel, and well what else is? not to mention I have 2 sets of them.. But possibly a change to methods is in my future. +25 may be the ticket, but +0.. is possible with a skinny, maybe.. I will be doing 2.5-3" of lift with OME mat likely once I weight the truck fully..
right now I have zero clearance issues with a RW and 285/70-17 Cooper AT3 XLT.. At 11.4" wide.. but it is 1" smaller (32.83") than the same 285/75-17 (33.82" but also 11.5" wide so not much different in width)...
