Build 2UZFE swap into FJ80 - building - in progress
Here is a video of the running cruiser.
YouTube - Toyota V8 FJ80 Landcruiser
Shorty headers with true dual 2 1/2" mandrel exhaust. Two cats which then lead to an X-pipe then to dual 44 series flowmaster.
No tailpipe yet so it will mellow out a little.
more pics
^ should have tig welded this too, my mig on thin walled tubing SUCKS!!
My tig welds on the x-pipe look much better.
Thanks.
1/8" I believe. It is the same thickness of the stock flex.
The adapter ring is 1/2" but next time it would be 3/4" in order to have another 1/4" of clearance between the two flex plates. Getting the flex plate bolts in was a PITA!!!
On the drivers side, it is basically just like a stock system. On the passenger side, it is basically the same thing. I have the cats mounted where the stock cat would have been located, but now I have them on either side. The x-pipe sits where the stock muffler used to sit.
I will take a picture of the entire undercarriage tomorrow.
big thanks dude ... if you have a chance a pic of your conections are big time appreciated .. and then you are using a DBW gas pedal . ? use the factory harness or make your own .. the pedal it's conected to the MAP at the intake or to the ECU .?
I made my own harness for the pedal. It goes into the (A) connector on the ECU, pretty easy.
I will take a picture of my rats nest wiring, then again once it is 100% complete.
well, when you're ready to roll with it, let me know and I may need to come down and check it out and maybe take it for a spin.
Drop by my house, too, will ya? I'm between Syracuse and Orem. ;) :D
Gonna bring this to the top.
Had the pleasure of seeing this in person last night, and let me tell ya, this thing is awesome! The wiring is not as bad as you guys might think, and the exhaust note... Ohhh baby. The video does it no justice. Firing up a motor with no tailpipes at 1:00 am is really something :lol:
Good to meet ya, Rob.
Let me add one more. After about an hour of frustration last night I found out that without this one, the gas pedal won't work.
On the ECU(+B ETC). Doesn't make a lot of sense, but it was required.
ECU:
+B
IGSW
BATT
IH1 connector:
Power to MAP
Power to injectors
Power to igniter
This is all you need to actually start/run the engine. Only if the ECU does not have an Immobilzer. I specifically ordered a 2005 tundra ECU for that reason.
