- Joined
- Sep 21, 2003
- Threads
- 78
- Messages
- 585
- Thread starter
- #21
New question. After verifying that my crank bearings and rod bearings are all ready to install, I was spraying carb cleaner through each oil hole in the block. I came across something that can't be right in my mind. The #2 cam bearing has two holes in it. One that goes between the crank and cam. The other should be going to the pump, correct? The PO said the motor ran fine but you can see in the pictures that the second hole is facing the block, not the oil pump line hole. It doesn't not look like the bearing has spun. This is installed incorrectly. Right? The motor is upside down in the pics but you can see the oil passages in the block.
