- Joined
- Sep 21, 2003
- Threads
- 78
- Messages
- 585
- Thread starter
- #81
I'm having a new issue with fuel. The engine has brand new fuel pump with the spacer as it's an 87 2f. I've always run a glass filter up near the carb. Right now I've got a disposable clear filter prior to the pump and the glass filter. The stainless headers on this engine produce a ton of heat. I'm running the 76 fan and fan clutch as the 87 one hits my power steering pump. Brand new radiator and I've run a coolant flush through the system. I'm running a Chinese knock off Aisin carb with no fuel return line. I have not replaced the thermostat. I also noticed that 30+ yrs ago the plastic part of the fan was modified to fit the fan shroud. Each fin was shortened. The symptom is that at 50mph or higher or running at high rpm's,, fuel doesn't seem to get the the carb. The engine will sputter and die. If i get off the throttle soon enough and let it idles, the fuel bowl seems to fill back up. The fuel in the glass filter almost looks like it's boiling, maybe causing vapor lock? I made an aluminum heat shield Friday that covers the front three exhaust pipes. The issue was still there if i went over 50-55 on an hour drive that night. The odd thing is that this didn't happen in the first couple weeks after the motor install, even on hot days. Any thoughts?
