2022 HZJ79 to a 2022 HDJ79
I need to try that product out. I have only done the dynamat route thus far.
Very nice work indeed
Just need our valve cover and intercooler back from the coater to finish it off.
Cheers
All the coating is done, tape pulled, letting it cure over the weekend.
Cheers
Roof got a Second Skin sound deadening/ heat insulation pad installed today.
Amp is wired, sub is wired, speaker wire ran to all four doors and more done as well. Such as Unichip mounted here,
Cheers
Headliner back in along with this,
Sub, amp and back panel all done, added a piece of OEM trim only found in single cabs too.
Cheers
Headliner
Installed an OEM antenna, yup drilled the fender to do that.
Our Unichip map selection switch and a boost/EGT combo gauge from Auber.
Cheers
Dropped the fuel tank so we can increase the size of the pickup tube in it.
Engine wiring harness build in the works.
Cheers
Chris has pretty much finished our in house 1HDFTE engine swap harness.
This plugs into the factory wiring harnesses.
Various sensors.
Relay for engine controls.
Firewall pass through.
Cheers
The center console is meant to replace a factory console. This Cruiser lacks the console brackets on the floor since it originally was a bench seat truck. They sent some brackets but they were just to whimpy and allowed the console to vibrate and not be very solid. So I made some new brackets out of 1/8” stainless steel and it is super solid now.
Cheers
We had an excellent week on the project!
More pics and…..videos coming!
Cheers
