2022 HZJ79 to a 2022 HDJ79
I'm sorry, but I just love that 1HZ sound.
12HT and 1VDFTV are the top two noise-makers.
12HT for the inline fans and 1VDFTV for the V-block fans. Both play wonderful symphonies.
Cheers
1HZ is out, without a doubt the easiest engine to pull in a new production vehicle anywhere!
Pulled front coils and checked for clearances with new lift, all good.
The 1HZ and trans we have for sale now.
Cheers
The last few days has been building out FTE swap harness.
Unichip with OEM Toyota plugs so it can simply be removed or installed by plugging in these two plugs.
ECU wiring.
Love this wire we found for projects like this. Everything matches OEM down to the color and stripe. 20yrs from now you can use the Toyota EWDs for this truck and it matches.
Cheers
Bulkhead connection for our engine harness pass through on the firewall.
Interior stripped, doing sound deadening while we are doing the swap.
Not bad progress for six working days! 😆
Cheers
ECU wiring.
Cheers
What wire is this? I need to rebuild my OEM harness for my carby 1FZ-F
Test fitting one more time.
I figured it needs this.
Cleaning this out of the bottom of the doors, factory wax with some dirt in it.
Cheers
Test fitting, 70th Anniversary front shifter console going in as well.
Being a factory 60/40 front seat this one never had a console. As such there are no console mounting brackets. Few other things needed as well such as moving one of the RHS seat mounts and seat belt mount for the same side needs to be dealt with.
Cheers
