Both Eric Smith and friends went in this weekend from Tahoma and here are their Pre-Run reports:
This first came in from Eric Smith:
We made it in from Tahoma. Cadillac is pretty dry for the most part. There was no water bar needed at the log. I found one bathroom on the way into the springs that’s a bit beat up and there a few in dirty dozen that need work/replacement. There are also a lot of downed trees in dirty dozen. We did a lot of clearing trees on the trail. It is definitely possible to make it through, but I wouldn't recommend it for those not as experienced. There are still plenty of spots with lots of snow and water. It is melting fast though.
Also, we have 4 rigs broken down on the trail including mine. Two blown motors (mine being one of them) and two with front end issues. We are trying to work on getting those out next weekend. . I am probably going to have to do an engine swap in there, I don't think I will be able to get mine towed out. Mine is at the bottom of Cadillac near the water hole on the springs side, there is another one on Cadillac and two more in the snowy parts near miller.
There were a lot of people that went from loon to buck just fine. Buck has so much water and it rises at night. It is best to camp higher up away from the water.
Also, when driving out Tahoma side, when approaching the big water hole that separates Cadillac from the Springs, people need to stay to the left through the trees, if you go straight; you will submerge your truck and in cases like mine, blow your motor.
The other is from Kade Hendrick “Pooz”
We made it in all the way to the Springs from Tahoma side. Looks like others have already gone in and cleared some of the trees. We had to cut it more like for buggies. Our rigs had 37” and 40” tires.
Two biggest issues:
1 – A 5’ bolder at the base of Morris Rock on Cadillac. We were able to crawl over it, but wagons would likely do a lot of body damage to get through.
To put things in perspective, I’m running 37’s and the drop is 2.5 times my tire.
This will need to be moved!
2 – There is a pool on the trail before the Cemetery, the area that is often a mud bug. Well right now it’s about 4’ deep.
There will be several work parties between now and Rubithon, so we should be good to go by then. If you go in early, be prepared, and I’d recommend using a long stick to sound the water before crossing.
Somewhat to my surprise, neither mentioned anything about crossing over Miller. Since they both go through to the Springs, I’m guessing it is ok, but cannot confirm.
Photos can be found on Rubithon's Facebook page. Having problems posting the videos.
